Integration by Parts - Proving Equations for m and n > 1
The discussion revolves around evaluating the integral J(m,n) = ∫₀^(π/2) cos^m(θ) sin^n(θ) dθ, specifically for cases where m and n are greater than 1. Participants are attempting to prove relationships involving this integral using integration by parts.
  • The original poster attempts to evaluate specific cases of the integral and apply integration by parts to derive reduction formulas. Some participants question the correctness of the terms derived during integration by parts and suggest alternative approaches to the problem.
Some guidance has been offered regarding the application of integration by parts, and participants are exploring different methods to manipulate the integral. There is acknowledgment of the complexity involved in proving the relationships, and one participant expresses uncertainty about the correct method to solve the problem.
Participants note the distinction between cases where m+n is odd or even, which may affect the approach to the problem. There is also mention of reliance on reduction formulas for trigonometric integrals, indicating potential constraints in the methods being discussed.
Bazman
Hi,
[tex]J(m,n) = \int_0^{\frac{\pi}{2}} \cos^m \theta \sin^n \theta d\theta[/tex]
First of all I had to evaluate the following ( I don't know what the correct answers are but here are my calculations:
[tex]J(0,0) = [\theta]_0^{\frac{{\pi}{2}}}=\frac{\pi}{2}[/tex]
[tex]J(0,1) = [-\cos \theta]_0^{\frac{{\pi}{2}}}= 1[/tex]
[tex]J(1,0) = [ \sin\theta]_0^{\frac{{\pi}{2}}}= 1[/tex]
[tex]J(1,1) = [\frac{-\cos 2\theta}{4}]_0^{\frac{{\pi}{2}}}= \frac{1}{2}[/tex]
[tex]J(m,1) = [-\frac{\cos^{m+1} \theta}{m+1}]_0^{\frac{{\pi}{2}}}= \frac{1}{m+1}[/tex]
[tex]J(1,n) = [\frac{\sin^{n+1} \theta}{n+1}]_0^{\frac{{\pi}{2}}}= \frac {1}{n+1}[/tex]
Next I am supposed to use integration by parts to prove that for m and n > 1
[tex]J(m,n) = \frac{m-1}{m+n} J(m-2,n)[/tex]
and
[tex]J(m,n) = \frac{n-1}{m+n} J(m,n-2)[/tex]
When I carried out integration by parts I got the following:
taking
[tex]u = \sin^{n-1} \theta[/tex]
[tex]u' = (n-1) \sin^{n-2}\theta \cos \theta[/tex]
[tex]v' = \cos^m \theta \sin \theta[/tex]
[tex]v = -\frac{cos^{m+1}\theta}{m+1}[/tex]
[tex]\frac{-\sin^{n-1} \theta \cos^{m+1}\theta}{m+1} + \int_0^{\frac{\pi}{2}} \frac{n-1}{m+1} \sin^{n-2} \theta \cos^{m+2} \theta d\theta[/tex]
the first term on the RHS equates to zero but the 2nd term is not correct: the denominator and the power to which cos is raised is wrong but I'm not sure how to fix it
I don't know why, but your LaTeX part is a bit messy for me. :frown:
You are correct to the last part. So, you have shown that:
[tex]\int_0 ^ \frac{\pi}{2} \cos ^ m \theta \sin ^ n \theta d( \theta ) = \frac{n - 1}{m + 1} \int_0 ^ \frac{\pi}{2} \cos ^ {\fbox{m + 2}} \theta \sin ^ {\fbox{n - 2}} \theta d( \theta )[/tex]
Note that cos function on the RHS is to the power of m + 2, and you want to prove that:
[tex]\int_0 ^ \frac{\pi}{2} \cos ^ m \theta \sin ^ n \theta d( \theta ) = \frac{n - 1}{m + n} \int_0 ^ \frac{\pi}{2} \cos ^ {\fbox{m}} \theta \sin ^ {\fbox{n - 2}} \theta d( \theta )[/tex].
So what you should do is to split cosm + 2(x) to cosm(x)cos2(x) = cosm(1 - sin2(x)), like this:
[tex]RHS = \frac{n - 1}{m + 1} \int_0 ^ \frac{\pi}{2} \cos ^ {m} \theta (1 - \sin ^ 2 \theta) \sin ^ {n - 2} \theta d( \theta ) = \frac{n - 1}{m + 1} \left( \int_0 ^ \frac{\pi}{2} \cos ^ {m} \theta \sin ^ {n - 2} \theta d( \theta ) - \int_0 ^ \frac{\pi}{2} \cos ^ {m} \theta \sin ^ {n} \theta d( \theta ) \right)[/tex].
So we have:
[tex]J(m, n) = \frac{n - 1}{m + 1} \left( J(m, n - 2) - J(m, n) \right)[/tex]
Can you go from here? :)
The other can be done almost the same, except for the first step:
Instead of choosing
u = sinn - 1(x)
and dv = cosm(x) sin(x) dx, we choose:
u = cosm - 1(x)
and dv = sinn(x) cos(x) dx.
Can you complete the two problems? :smile:
Hey VietDao29!
Thanks for your help on this.
I assume that the rest of the answer rely's on my using the reduction formula for trigonometric integrals?
I've had a quick scoot on the web and there seems to be two main cases m+n odd or m+n even. Which uses two different formula (which does make me a little anxious as there is only one formula that we are trying to prove.)
Anyway I've included a link to the worksheet I am working from.
http://www.math.uAlberta.ca/~apotapov/MATH115/trinth.pdf
Is this the correct method to solve the problem?
Hi VietDao,
I managed to figure it out.
Your hint brought me a lot closer to the solution than I initially realized!
Thanks again :smile:
  • · Replies 19 ·
