Thread Closed
How to determine if the mixing of two solution would result in buffer solution?
Share Thread Thread Tools
Apr13-07, 04:31 PM   #1
Red face
Which of the following mixtures would result in buffered solutions whn 1.0 L of each of the two solutions are mixed?
(i) 0.10 M sodium chloride and 0.10 M sodium nitrite
(ii) 0.10 M sodium chloride and 0.10 M ammonium chloride
(iii) 0.10 M hydrochloric acid and 0.10 M ammonia
(iv) 0.20 M hydrochoric acid and 0.10 M ammonia
(v) 0.10 M hydrochloric acid and 0.20 M ammonia
2. Relevant equations
All I know is that there are 6 methods by which we can buffer solutions:
(i) weak acid and strong base
(ii) weak base ans strong acid
(iii) weak and its salt
(iv) weak base and its salt
(v) salt of weak acid and strong acid
(vi) salt of weak base and strong base
3. The attempt at a solution
but when I use the above knowledge, the answer are coming different ... the thing I'm not getting is how the molarity of each of the solutions would have an effect.
I have the answers for the above parts but I don't know the reasoning .....
(i) No
(ii) No
(iii) No
(iv) No
(v) Yes
Can anyone please please immediately and somehow explain me the reasoning ...... I'll be really thankful ....
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr13-07, 04:53 PM   #2
Admin
Buffer must contain conjugated pair of acid/base. Preparation methods are a consequence of this.
Borek
Chemical calculators at www.chembuddy.com
equation balancer and stoichiometry calculator
pH calculator
concentration conversion
Apr13-07, 06:20 PM   #3
Quote by Borek View Post
Borek
pH calculator
Hey there, thankyou for the links , but do you know how to find the answers without using chemical calculator ... I've an exam tomorrow.
Apr16-07, 04:17 PM   #4
Admin
Too late I presume... But to find the answers to your questions you should follow not my links, but information about what the buffer is. Take a look at all solutions defined - IF they contain both acid and conjugated base (especially in comparable quantities) you have a buffer solution.
Borek
General Chemistry Software
www.pH-meter.info/pH-electrode
Thread Closed
Thread Tools
Similar Threads for: How to determine if the mixing of two solution would result in buffer solution?
Thread Forum Replies
ph of buffer solution Biology, Chemistry & Other Homework 2
pH of buffer solution Biology, Chemistry & Other Homework 5
pH of buffer solution Biology, Chemistry & Other Homework 2
pH of a buffer solution Biology, Chemistry & Other Homework 2
Buffer solution Chemistry 1
