Work done by the spring on an object
The discussion revolves around a problem involving an ideal spring and the work done by the spring when a mass is hung from it and further extended by an external force. The context includes concepts from mechanics, specifically related to springs and potential energy.
  • Participants discuss the application of formulas related to spring potential energy and the definition of work. There are questions about how to appropriately use these formulas in the context of the problem.
The discussion is ongoing, with participants providing guidance on the relationship between work and potential energy. Some participants suggest that a clearer understanding of the formulas is necessary for progress.
There is mention of confusion regarding the correct application of formulas and the distinction between potential energy and force in the context of the problem. Participants are encouraged to refer to their texts for clarification.
DrHughes
20) An ideal spring is hung vertically from the ceiling. When a mass 2.0 kg hangs at rest from it, the spring is extended 6.0 cm from its relaxed length. A downward external force is now applied to the mass to extend the spring an additional 10cm. While the spring is being extended by the force, the work done by the spring is:
a) – 4.2 J
b) – 3.6 J
c) – 3.4 x 10-5 J
d) 3.6 J
e) 4.2 J
I know formulas like Fsp = 1/2 kx^2 etc .etc.
I still don't know how to put them to use in this context
The formula you wrote is for the potential energy of the spring - not the force. This is not a good start. You'll have to make a better start before people can begin to help you.
If you want you can use energy to solve this question. Do you know how work and the change of potential energy are related?
There's nothing wrong with using this formula for spring PE, if you know what it means. (Check your text!)
You can also attack the problem directly by considering the definition of work.
  • · Replies 58 ·
