Calculating pH Change in C6H5COOH Solution with KOH Addition
  • Thread starter Thread starter lizzyb
    Acid koh
The discussion revolves around calculating the change in pH of a 0.400 M C6H5COOH (benzoic acid) solution upon the addition of 100.0 ml of a 2.50 M KOH (potassium hydroxide) solution. Participants explore the theoretical and mathematical aspects of acid-base neutralization, equilibrium expressions, and the application of the Henderson-Hasselbalch equation.
  • One participant calculates the initial pH of the C6H5COOH solution using its dissociation constant (Ka) and proposes that KOH will neutralize some of the acid, leading to the formation of C6H5COO-.
  • Another participant suggests determining the formality of both the C6H5COOH and its potassium salt after the addition of KOH, questioning whether there is excess KOH.
  • Participants discuss the moles of acetic acid and KOH, with one stating that all KOH is used up in the reaction, leaving a certain amount of acetic acid remaining.
  • Several participants present calculations for the formality of the remaining acid and the salt formed, emphasizing the need to account for these in the equilibrium expression.
  • There is a mention of the Henderson-Hasselbalch equation, with one participant asserting that the volume cancels out, allowing the use of moles directly in the calculations.
  • One participant expresses confusion over the identification of C6H5COOH as acetic acid, indicating a potential misunderstanding in the naming of the compounds involved.
  • Another participant notes discrepancies in calculated values, suggesting that while differences exist, they may not be fundamentally significant.
Participants exhibit a mix of agreement and disagreement regarding the calculations and interpretations of the acid-base reaction. There is no consensus on the final pH value or the calculations leading to it, with multiple viewpoints and methods presented.
Participants rely on various assumptions regarding the behavior of weak acids and strong bases, the definitions of formality, and the application of equilibrium constants. Some calculations are presented without complete clarity on the steps taken, leading to potential ambiguities in the results.
lizzyb
Question:
Calculate the change in pH of a 0.400 M C6H5COOH solution when 100.0 ml of a 2.50 M KOH solution is added to 1.000 L of C6H5COOH. For C6H5COOH, Ka = 6.46 X 10^-5.
Work Done So Far:
We're to determine the change in pH, thus we'll need to find the original pH.
Ka = 6.46 X 10^-5 = x^2/(.4-x) ==> x = .0050511 ==> pH = 2.296
What should I do next? I understand that KOH is a strong base so it will tear the excess H off of C6H5COOH leaving C6H5COO-, but do we need to account for the H+ left over from the C6H5COOH there before the KOH was added?
Can you now use the given information to find the formality of C6H5COOH and the formality of its potassium salt? Also, is there excess KOH?
One idea was to count the number of moles of each and then recognize that the OH will pull the H off of C6H5COOH, so after it does that, then there will be excess OH-.
Moles Acetic: .400 M * 1L = .4 moles
Moles KOH: .250 M * .1 L = .025 moles
In this case, there is not an excess number of KOH, so all the OH is used up removing H from the acetic acid.
Moles Acetic Acid left: .4 - .025 = .375 moles
Its new molarity is: .375 moles / 1.1L = .341 M
How do I determine the pH from this? Should I just do it like I did before taking the molarity as .341 M?
\eqalign{
& \text{Refer to reaction} \cr
& \text{HAc } \Leftrightarrow \text{ H + + Ac - } \cr
& \text{Each mole of HAc which dissociates yields one mole of H and one mole of Ac}\text{.} \cr
& \text{Molarity of any Ac } = \;Fsalt\; + \;H \cr
& \text{Molarity of any HAc } = \;Facid\; - \;H \cr
& \text{Note that the word salt means KAc (potassium acetate)}\text{.} \cr
& \cr
& \text{Formality of remaining acid after neutralization: } \cr
& \frac{{1L \times 0.4M}}
{{1.100L}}\; - \;\frac{{0.1L \times 2.5M}}
{{1.100L}}\; = \;0.136F\,HAc \cr
& \cr
& \text{Formality of the salt KAc formed in solution is:} \cr
& \frac{{0.1L \times 2.5M}}
{{1.100L}}\; = \;0.227F\,KAc \cr
& \cr
& \text{The equilibrium constant expression for which you already have the value of }6.46 \times 10^{ - 5} \cr
& K\; = \;\frac{{[H][Fsalt + \,H]}}
{{[Facid\; - \;H]}} \cr
& \cr
& \text{Now, just put the equation into general form for a quadratic equation and find } \cr
& \text{for [H], and then simply substitute the known values and compute}\text{. You can do } \cr
& \text{similarly for the initial acid solution before any KOH were added to find the} \cr
& \text{initial [H] value}\text{.} \cr}
[tex]$$<br /> \eqalign{<br /> & {\rm Refer to reaction} \cr <br /> & {\rm HAc } \Leftrightarrow {\rm H + + Ac - } \cr <br /> & {\rm Each mole of HAc which dissociates yields one mole of H and one mole of Ac}{\rm .} \cr <br /> & {\rm Molarity of any Ac } = \;Fsalt\; + \;H \cr <br /> & {\rm Molarity of any HAc } = \;Facid\; - \;H \cr <br /> & {\rm Note that the word salt means KAc (potassium acetate)}{\rm .} \cr <br /> & \cr <br /> & {\rm Formality of remaining acid after neutralization: } \cr <br /> & {{1L \times 0.4M} \over {1.100L}}\; - \;{{0.1L \times 2.5M} \over {1.100L}}\; = \;0.136F\,HAc \cr <br /> & \cr <br /> & {\rm Formality of the salt KAc formed in solution is:} \cr <br /> & {{0.1L \times 2.5M} \over {1.100L}}\; = \;0.227F\,KAc \cr <br /> & \cr <br /> & {\rm The equilibrium constant expression for which you already have the value of }6.46 \times 10^{ - 5} \cr <br /> & K\; = \;{{[H][Fsalt + \,H]} \over {[Facid\; - \;H]}} \cr <br /> & \cr <br /> & {\rm Now, just put the equation into general form for a quadratic equation and find } \cr <br /> & {\rm for [H], and then simply substitute the known values and compute}{\rm . You can do } \cr <br /> & {\rm similarly for the initial acid solution before any KOH were added to find the} \cr <br /> & {\rm initial [H] value}{\rm .} \cr} <br /> $$[/tex]
I have been trying but the typesetting through TexAide does not work in the message.
did it in ascii-ese
Code:
Refer to reaction
HAc <--> H+ + Ac-
Molarity of any Ac = Fsalt + H
Molarity of any HAc= Facid - H
Note that the word salt means KAc (potassium acetate).
   1L * .04M     .1L * 2.5M
 ------------ - ---------- = .136F HAc
   1.100 L        1.100 L
   .1L * 2.5M
   ----------- = .227 F KAc
     1.100 L
the value of 6.46 X  10^-5
    [H][Fsalt + H]
K = ---------------
     [Facid - H]
for [H], and then simply substitute the known values and compute. You can do
initial [H] value
there is the formula
Code:
                [salt]
pH = pKa + log(--------)
                [acid]
             2.5M * .1 L
so [salt] = ------------- = .227 M
              1.1 L
              .4 M * 1 L
    [acid] = --------------- = .36 M
                1.1 L
                       [salt]
pH = -log(Ka) + log( ---------) = .399
                       [acid]
is that okay? thanks for your help.
One more try, copied from Jarte wordprocessor:
It WILL NOT paste.
You appear to have most of the details well in place, but a couple of the calculated values are different than mine. Probably no fundamental big deal.
Since when benzoic acid is acetic acid?
This is classic buffer question.
You start with 0.4 mole of weak acid.
You add 0.25 mole of strong base.
After neutralization you have 0.15 mole of weak acid left and 0.25 mole of conjugated base present in the solution.
You put these values into the Henderson-Hasselbalch equation. You even don't have to calculate concentrations, as the volume cancels out, so numbers of moles are enough.
If you really want to, you may check the calculations using (free trial will do).
  • · Replies 16 ·
