How can the limit of this function be shown to be 2 as x and y approach 0?
  • Thread starter Thread starter oahsen
    Limit
The discussion revolves around evaluating the limit of the function \( \frac{2x}{x^2 + x + y^2} \) as \( (x, y) \) approaches \( (0, 0) \). Participants are exploring the behavior of the limit and whether it can be shown to equal 2.
  • Exploratory, Assumption checking, Mixed
  • Some participants suggest evaluating the limit by considering the paths along the x and y axes separately. Others propose using polar coordinates to analyze the limit as \( r \) approaches zero.
There is an ongoing exploration of different approaches to the limit, with some participants asserting that the limit should be independent of the path taken. Several interpretations of the limit's behavior have been presented, but no consensus has been reached regarding its existence or value.
Participants note that the limit appears to yield different results depending on the path taken, raising questions about the limit's existence. There are also references to the function being identically zero along certain paths, which complicates the evaluation.
oahsen
as x,y goes to 0,0 lim(2x/(x^2+x+y^2)
It is obvious that the limit is 2 but I can not show it. I tried to change polar coordinates etc. but nothing did not help. What should I do?
I would suggest doing limits for each varable separately
make either x=0 or y=0 and do the limits separately, or in other words, the limit in the y direction or x direction.
First take the limit as y goes to 0, to get to
lim(2x/(x^2+x)).
Divide out the common factor of x to get
lim(2/(1+x))
Taking this limit will give 2.
You can't do that. the point is that it has to be independent of the path chosen. You cannot let y tend to zero, then x tend to zero - this is just taking a path along the x axis.
The best advice I heard was to always convert to polars and then let r tend to zero.
Let t be theta then we have
2rcos(t)/(r^2+rcos(t)) = 2cos(t)/(r+cos(t))
As r tends to zero that tends to 2, as long as cos(t) is not zero.
this of course shows that the limit does not exist, contrary to what the OP asked. But then that was obvious anyway: on the y-axis (so x=0) away from y=0 that function is identically zero.
lim(2x/(x^2+x)).
lim(2/(1+x))
Yes, this is correct, and in the Y direction the limit is negligible because it goes to zero and the limit goes to zero if you ignore the x direction.
lim(2x/(x^2+x)).
lim(2/(1+x))
OK, if "y goes to 0" first, you get 2x/(x2+ x)= 2/(x+1) which goes to 2 as x goes to 0. If x goes to 0 first, you get 0/y = 0 which goes to 0 as y goes to 0. What does that tell you about the limit itself?
corrections: limit does not exist for f(x,y), because limit in the x direction = 2 and in the y = 0.
Quite right, the limit should be the same along all dimensions under consideration or it doesn't exist.
