Fractional energy in a damped harmonic oscillator
The fractional energy lost per period in a damped harmonic oscillator is defined by the equation \(\frac{\Delta E}{E} = \frac{2\pi b}{m\omega_0}\), where \(\omega_0 = \sqrt{\frac{k}{m}}\) and \(Q = \frac{m\omega_0}{b}\). The energy change over one cycle is calculated as \(\Delta E = \frac{1}{2} k A^2 e^{-(b/m)(t + T)} - \frac{1}{2} k A^2 e^{-(b/m)t}\), leading to \(\frac{\Delta E}{E} = e^{-\frac{2\pi b}{m\omega_0}} - 1\). The negative sign in the energy change indicates a loss, aligning with the requirement to express energy lost as a positive quantity.
  • Understanding of damped harmonic motion
  • Familiarity with the Taylor series expansion
  • Knowledge of the concepts of energy in oscillatory systems
  • Basic proficiency in calculus and differential equations
  • Study the derivation of the damping ratio in harmonic oscillators
  • Explore the implications of the quality factor (Q) in oscillatory systems
  • Learn about the effects of damping on resonance frequency
  • Investigate the application of Taylor series in physics problems
Students and professionals in physics, particularly those focusing on mechanical vibrations, engineers working with oscillatory systems, and anyone studying energy loss in damped systems.
endeavor
Show that the fractional energy lost per period is
[tex]\frac{\Delta E}{E} = \frac{2\pi b}{m\omega_0} = \frac{2\pi}{Q}[/tex]
where [tex]\omega_0 = \srqt{k/m}[/tex] and [tex]Q = m\omega_0 / b[/tex]
[tex]E = 1/2 k A^2 e^{-(b/m)t} = E_0 e^{-(b/m)t}[/tex]
[tex]\Delta E = 1/2 k A^2 e^{-(b/m)(t + T)} - 1/2 k A^2 e^{-(b/m)t}[/tex] where [tex]T = 2\pi / \omega_0[/tex]
[tex]\frac{\Delta E}{E} = e^{-(b/m)T} - 1[/tex]
[tex]\frac{\Delta E}{E} = e^{-\frac{2\pi b}{m\omega_0}} - 1[/tex]
What should I do now?
Using the Taylor series of e^x,
[tex]e^{-(2\pi b)/(m\omega_0)} = 1 + -\frac{2\pi b}{m\omega_0}[/tex]
Can you explain why I would drop the rest of the terms?
So
[tex]\frac{\Delta E}{E} = -\frac{2\pi b}{m\omega_0}[/tex]
first of all, is this right?
second, how do i account for the negative sign?
All this assumes the damping is small, i.e. b << m \omega_0, so you can drop the higher terms of the Taylor series.
Re the negative sign, the question asks for the fractional energy lost.
Energy lost in 1 cycle (a positive number) = Initial energy - final energy.
Your equation found the change in energy as
Change in energy in 1 cycle (a negative number) = final energy - initial energy.
