Calculate the pH of Buffer Solution with Ka=1.34x10^-5
  • Thread starter Thread starter lizzyb
    Buffer Ph
The pH of a buffer solution prepared by mixing 380.0 ml of 0.250 M propionic acid (C2H5COOH) and 120.0 ml of 0.350 M sodium propionate (C2H5COONa) is calculated to be 3.002. The dissociation constant (Ka) for propionic acid is 1.34 x 10^-5. Initial concentrations were determined to be 0.19 M for propionic acid and 0.084 M for sodium propionate. The equilibrium concentrations were calculated using the x-method, confirming the accuracy of the pH calculation.
  • Understanding of buffer solutions and their components
  • Knowledge of acid dissociation constants (Ka)
  • Familiarity with equilibrium calculations in chemistry
  • Proficiency in logarithmic functions for pH calculations
  • Study the Henderson-Hasselbalch equation for buffer pH calculations
  • Explore the concept of buffer capacity and its significance
  • Learn about different types of buffer solutions and their applications
  • Investigate the effects of dilution on buffer pH stability
Chemistry students, laboratory technicians, and professionals involved in chemical analysis or formulation of buffer solutions.
lizzyb
Question
A buffer solution is prepared by mixing 380.0 ml of 0.250 M propionic acid, C2H5COOH, and 120.0 ml of 0.350 M sodium propionate, C2H5COONa. Calculate the pH of the prepared buffer solution. For propionic acid, Ka = 1.34 X 10^-5.
Work thus far
Code:
  We have this
  C2H5COOH <--> C2H5COO- + H+
  Since the C2H5COONa goes to completion and is left
  with C2H5COO-, we can determine the initial amount
  of C2H5COO-, and then we use the x-method to determine
  the pH.
  Initial Molarities:
                 .250 M .380 L     .250 * .380
   [C2H5COOH] = --------------- = ------------ = .19 M
                 (.380 + .120)L        .5
                 .350 M * .12 L     .350 * .12
   [C2H5COO-] = ---------------- = ------------ = .084 M
                 (.380 + .120) L      .5
    .19                 .084               0       initial
     -x                  x                 x       change
   .19-x               .084+x              x       equilibrium
  so,
                         (.084 + x) x
     Ka = 1.34 X 10^-5 = --------------
                          (.19-x)
     ==> x = 3.029 X 10^-5, pH = -log(x) = 3.002
does this look okay to you?
Yes. ... ..
thank you! :-)
  • · Replies 16 ·
  • · Replies 16 ·
