Calculating Temperature Rise in H2SO4 Dissolution: 98% wt. Acid at 30oC"
  • Thread starter Thread starter moleman1985
The discussion revolves around calculating the temperature rise during the dissolution of 98% weight H2SO4 in water, considering the initial and final concentrations, temperatures, and the heat of dissolution. Participants explore various factors that may influence the temperature change, including phase states and heat transfer dynamics in a specific system setup.
  • Experimental/applied
  • One participant mentions the heat of dissolution as -71.76 kJ/mol but questions its applicability due to the non-infinite dilution of the acid.
  • Another participant raises the issue of whether to consider the heat of condensation for water transitioning from vapor to liquid phase.
  • Some participants express uncertainty about the relevance of the water phase, with one suggesting that it is not steam at 30 °C under 1 atm pressure.
  • A participant calculates that the total energy released by the dissociation of H2SO4 could be around 83170 kJ, but questions the validity of their calculations due to the high resulting temperature.
  • Concerns are raised about the potential for dangerous temperatures, with one participant suggesting a cooling medium is necessary.
  • Another participant speculates on the possibility of reducing the heating effect due to non-infinite dilution and expresses a desire to minimize cooling costs.
  • One participant discusses the complexity of heat transfer in an absorption tower setup, indicating that both the acid and gas phases will increase in temperature but presumes no heat transfer from counter flows.
  • A later reply suggests that the heating of the gas should also be considered, noting that their calculations indicate a maximum temperature of 55.65 °C, which aligns with optimal absorption conditions.
  • Participants debate the heat of dissolution values, with one expressing skepticism about a value found online and suggesting it may not be reliable.
  • Some participants acknowledge their status as students and express uncertainty about their calculations and assumptions.
Participants do not reach a consensus on several key points, including the relevance of the heat of condensation, the proper heat of dissolution value, and the assumptions regarding heat transfer in the system. Multiple competing views remain throughout the discussion.
Participants express uncertainty about the assumptions made regarding phase states, heat transfer dynamics, and the applicability of various heat of dissolution values. The discussion reflects a range of calculations and hypotheses that are not fully resolved.
This discussion may be useful for students and professionals involved in chemical engineering, particularly those interested in thermodynamics, heat transfer, and the behavior of acid solutions in industrial applications.
moleman1985
Hello, I have the following problem and am unsure how to solve it, although I believe the heat of dissolution to be -71.76kJ/mol, but I can only see how this would help me if my acid was infinetly dissoluted which is not the case so I need to know how the calculate a temperature rise when this is not the case.
My acid starts off at 98% wt. total wieght 115.985041 kg, (1158.9 moles H2SO4, and 128.8 moles H2O).
The acid ends up at 75% wt. total weight 151.55284 kg, (1158.9 moles H2SO4, and 2103.1 moles H20).
Both the acid and water initial temps can be taken as 30oC,
So basically 115.98kg of 98% wt. H2SO4 at 30oC, with 35.5kg water at 30oC
the water is also in vapour phase at the beginning, so will I also have to consider the heat of condensation of the water going from the vapour phase to the liquid phase? thankyou.
I vote no to the second question, but I'm not sure. It's not like it's steam? If the pressure is 1 atm of course... They are little particles of water at 30 °C.
And, the solution of H2SO4 seems 18 M so, I think you may use the formula of:
http://people.depauw.edu/harvey/Chem 260/pdf files/Worksheets/EnthalpyStrongAcidKey.pdf
Which you posted yourself.
So if all H2SO4 dissociates it will give: 83170 kJ of energy to the solution.
For the warmth capacity I'd say approximately:
H2SO4: 3,5 J/gC . 113000 g = 400 kJ/C
H2O: 4,18 J/gC . 35,3 kg = 150 kJ/C
So dQ = (cp1m1 + cp2m2) dT
dT = 152 ° C
Oh boy, there must be something wrong with the calculation? Hey I'm not a professional... yet.
Your reactor is going to explode... do you have some kind of cooling medium?
The boiling point of H2SO4 was something at 350°C so maybe, just maybe your solution won't evaporate at 180 °C. Otherwise, you're in a big trouble. I don't know how your installation looks like, so that info would be interesting too.
I'm curious myself how you're going to handle this calculation! Please post everything you got.
Hi can I just say first thanks loads for your reply, I will be using a cooling loop in the system, sorry but I gave you all the information I got, but it going to 150oC sounds correct. So do you recon that I would be able to half or maybe even third the heating due to it not beening infinet dilution woukld you be able to hazard a guess with a vague explanation, if not it doesn't matter too much all I need to do is put in my report that I presume that it is infinet dissolution, its just that I don't want to be using more cooling than I sholud as I have to do a detailed costing on the system.
One other thing I also found the heat of dissolution to be 800kJ/mol, but that was on wiapedia.com, or however it's spelt, so it's probably not reliable.
Thanks loads.
I'm just looking for a basic temperature rise, the whole system is an absorption tower, a wet gas feed at the bottom, and the acid feed at top, so somehow I'm also going to have to come up with a compromise of the two phases increasing with temperature due to the dissolution and the general heat transfere between the two counter flows as both streams will rise in temperature but flow past the inlet streams as they exit which will be at the original lower temperature, but I'm probably just going to say and presume there is no heat transfer from counter flows but that both the acid and gas are heated together to the same temperature, ha lazy...!
hi, would you not also have to take into consideration the heating of the gas via the acid (heat transfer), I have a spread sheet set up which considers this and as the gas flow rate is many time the liquid flow rate, and whole system only reaches 55.65oC, and this is good as the column works at optimum absorption at 55-60oC. This is assuming that the heat is shared equally let me know what you think of this if you think its a bad idea then I scrap it, thanks
So you spray HS2O4 above and you have some kind of gas at the bottom? Or is it air with water?
As for the 800 kJ/mol, that seems much! Meaning the reactor will even blow more up than I predicted. You should know exactly what you are doing here!
The thing is, I calculated that it's 18 M and the internet site also uses 18 M solution as an example. So the heat of reaction they use there should be correct. Maybe I read something wrong there.
I think -800 kJ/mol is the formation of HSO4- from pure H2SO4 (solid) with H2O and -70 kJ/mol takes in account the solution of H2SO4/H2O.
I'm just a student don't take me so seriously! I make mistakes. :)
11K
9K
  • · Replies 16 ·
  • · Replies 44 ·
