I really need to learn how to do Nodal Analysis by Inspection before Wednesday
The discussion revolves around understanding "Nodal Analysis by Inspection" in the context of circuit analysis. The original poster seeks clarification on this method before an upcoming deadline, referencing a quick explanation provided by their professor.
  • Exploratory, Conceptual clarification
  • Participants discuss the concept of nodal analysis and its application by inspection, with some asking for detailed explanations and examples. There are references to previously solved circuits and attempts to clarify the method's specifics.
Some participants have provided links to resources and examples, while others have shared insights about specific circuit characteristics. There appears to be a mix of interpretations regarding the "by Inspection" method, with no clear consensus yet on its application.
Participants are working under a time constraint, as the original poster needs to grasp the concept before Wednesday. There is mention of a previously solved circuit that may serve as a reference point for discussion.
VinnyCee
I really need to learn how to do "Nodal Analysis by Inspection" before Wednesday!
My Prof. told us (very quickly) about some easy method for circuit analysis called "Inspection". Can someone explain, in detail, how this is done? If you want a circuit to demonstrate on, just check my old posts and copy a suitable circuit from there to here.
Thanks!
Anyone here know how to explain the "by Inspection" part of Nodal Analysis?
Really late on this one but helpful for those who will be stuck.
This Place has the best explanation that I have found for node analysis or mesh analysis by inspection.
http://commons.bcit.ca/math/examples/elex/linear_algebra/backgd5a.html"
Though it is late, but no harm in commenting.
If you inspect that circuit, you will see that the voltage difference between terminals of the 40 Ohm is 120 V. The reason is that the positive terminal of the voltage source is connected to the other side of the 40 ohm resistor. Therefore, Io can be easily found; it is the current of the 40Ohm and we know the voltage drop of that. Thus, Io=120V/40 Ohm=3A.
For Vo, it is the voltage drop of a short circuit. Therefore, Vo=0V.
I solved some tricky problems http://circuits.solved-problems.com/basic-concepts/problem-1-13-voltage-current-source/" .
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 43 ·
