Can Naked Singularities Exist Through Scalar Field and Gravitational Collapse?
  • Context: Graduate
  • Thread starter Thread starter Huma waseem
    Singularity
The discussion centers on the possibility of naked singularities arising from scalar field collapse, dust collapse, and spherical gravitational collapse. Participants explore the implications of infinite redshift along outgoing geodesics from these singularities and the potential for information transmission from them.
  • Some participants propose that naked singularities could exist through various collapse mechanisms, including scalar fields and dust.
  • There is a discussion about the nature of infinite redshift, with one participant explaining that it implies no light can escape to infinity from a naked singularity.
  • Another participant questions whether light could escape to any distance short of infinity, prompting further exploration of the implications of redshift.
  • A detailed mathematical explanation is provided regarding the energy and frequency of light emitted from a singularity, suggesting that while light may escape to finite distances, it may not be detectable at large distances due to redshift effects.
  • One participant expresses gratitude for the explanations and indicates a desire to understand the mathematical details better.
Participants do not reach a consensus on the implications of infinite redshift or the nature of light escaping from naked singularities. Multiple competing views and interpretations remain present throughout the discussion.
The discussion includes complex mathematical relationships and assumptions about energy, frequency, and gravitational effects that are not fully resolved. The implications of these relationships on the existence and properties of naked singularities remain open to interpretation.
Huma waseem
Naked Singularity ... ?
How the Scaler Field collapse, Dust collapse and spherical gravitational collapse provide the possibility of existence of NAKED SINGULARITY?
Also can anyone explain me about this...
"In known examples of naked singularities for dust and perfect fluids, the redshift along outgoing geodesics emerging from the singularity is found to be infinite (when calculated for observers in the vacuum region). This could be interpreted to mean that no \information" is being transmitted from the naked singularity and could be yet another approach to preserving censorship. "
Space news on Phys.org
For the benefit of the non-scientist; how does an infinite redshift manifest itself?
Since the redshift of light emitted by an object is one plus the ratio of the change in wavelength divided by the wavelength at which it was emitted, infinite redshift requires that for any finite value of the emitted wavelength, the wavelength of the light received at infinity is infinitely long. This means that no light (or anything else emitted from the naked singularity) could escape (to infinity).
But it could escape to any distance short of infinity?
How would that differ from saying it could escape to any distance, since it could never reach infinity?
The energy [tex]E[/tex] (not including relativistic effects) due to gravity and motion of an object (I will call "O", because it looks like a 2-d planet.) with a mass, [tex]m[/tex], moving at a velocity, [tex]v[/tex], with respect to a much heavier object (I will call "S", for Sun) of mass, [tex]M[/tex], a distance, [tex]r[/tex], away is (approximately): [tex]\frac{1}{2}mv^{2}-\frac{GM}{r}[/tex] where [tex]G[/tex] is the universal gravitational constant. If [tex]E[/tex] is greater than zero, then O has a hyperbolic trajectory, it will come near S once and never return. All of the properties of these objects are constant except for their relative velocity, [tex]v[/tex], and the distance between them, [tex]r[/tex]. So, one can solve for the velocity of O in terms of a bunch of constants and the distance between the two objects: [tex]v=\sqrt{\frac{2E}{m}+\frac{2GM}{mr}}[/tex]. Now, take the limit as [tex]r[/tex] goes to infinity. If [tex]E[/tex] is positive or zero there are no problems, the second term under the square root gets smaller and smaller until in the limit, it goes to zero. The value of [tex]v[/tex] in this limit tells you something about the shape of the trajectory O has. If the value is zero, the shape is a parabola, if it is greater than zero the shape is a hyperbola. If the value under the square root becomes negative (which can only happen (when the other constants are positive) if [tex]E[/tex] is negative), then O cannot escape S and will forever orbit it. The case is slightly different for redshift and light, since the local speed of light is constant. What happens instead is that the energy/frequency of the light decreases (the kinetic energy of light is not given by the same equation as I gave above for O, instead it is proportional to the frequency of the light, so the frequency decreases in order for [tex]E[/tex] to remain constant as [tex]r[/tex] increases). So, similar situations to those for O can happen for light. Instead of velocity the frequency of the light at a given distance can be solved for: [tex]E=h\nu{}-\frac{GM}{r}\Rightarrow{}\nu{}=\frac{E}{h}+\frac{GM}{hr}[/tex], where [tex]h[/tex] is Planck's constant. So, similarly, if [tex]E[/tex] is positive, the light escapes S since as [tex]r[/tex] goes to infinity [tex]\nu{}[/tex] approaches a positive value. If [tex]E=0[/tex], then [tex]\nu{}[/tex] approaches zero as [tex]r[/tex] goes to infinity. This is the case of infinite redshift. What it means is that the farther one is from the naked singularity, the lower the frequency/energy of light one receives for a given frequency of light emitted.
So, theoretically, yes light could escape to any distance short of infinity. However, practically, if an instrument that can detect given range of frequencies is placed far enough from the singularity that emits a given (non-infinite) range of frequencies of light, it will not be able to detect anything.
Thanks, IsometricPion. I would ask, wouldn't I! Now I shall have to try to find time to make sense of those equations. Its a good thing you added the last 3 lines, at least I shall know what I'm aiming for. :smile:
  • · Replies 45 ·
  • · Replies 24 ·
  • · Replies 43 ·
9K
  • · Replies 21 ·
