Differential Equation Homework: Solving 1000(dp/dt) = p(100-p)
The discussion revolves around solving the differential equation 1000(dp/dt) = p(100-p), which is a first-order separable differential equation. The original poster expresses difficulty in progressing with the solution and mentions a related equation, dP/dt = P(1-0.01P)-h.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the method of separation of variables and the use of partial fractions for integration. The original poster attempts to manipulate the equation but encounters challenges with differentiation and integration. There is also mention of setting h = 0 for a related problem.
The discussion is ongoing, with participants providing suggestions for methods such as separation of variables and integration techniques. Some participants express confusion about specific steps, while others offer guidance on integrating the right-hand side of the equation.
The original poster indicates a lack of progress and expresses uncertainty about the integration process. There is also a mention of a second related differential equation that adds complexity to the discussion.
Illusionist
Hi, I've been trying to solve the differential equation 1000(dp/dt) = p(100-p), but have had no luck so far.
I think this requires using the change of variables formula.
Basically I've tried putting everything involving the dependent variable p, which lead me to [1000/(100p-p^2)]*(dp/dt)=1. I then tried to differentiate both sides but this is where I seem to become stuck. I know the answer is p= 200/(2-e^-0.1t) but can't get to it because of the integration.
I'm also having similar problems with the question dP/dt=P(1-0.01P)-h. Thanks in advance or any help or tips.
Just try separation of variables.
[tex] 1000\frac{{dp}}{{dt}} = p\left( {100 - p} \right) \Rightarrow \int {\frac{{dp}}{{p\left( {100 - p} \right)}} = \frac{1}{{1000}}\int {dt} } [/tex]
For the second one, set h = 0 and solve the ODE. Then solve dp/dt = -h and add the two solutions.
Yeah I got that far but I am having trouble differentiating the RHS of the equation.
do you remember integrating partial fractions? If not you should look it up. The right side looks pretty straight forward to me. Integrating it should be one step process. I don't know why you say RHS is a problem.
The next step following from what was in my last post would be to integrate both sides. The integral of 1 with respect to t is just t and the integral of (p(100-p))^-1 is fairly easy once you split it into partial fractions.
Of course, don't know what I was thinking. Sorry. Thanks a lot.
  • · Replies 25 ·
