| Thread Closed |
I need to write a function that reads words from a text file and |
Share Thread |
| Apr15-07, 11:09 PM | #1 |
I need to write a function that reads words from a text file and writes the words to an output tex file while removing all duplicate words.
void remove_dup(string filename) { vector <string> a; string word; ifstream infile(filename.c_str()); if(infile.fail()) exit(0); while(!infile.eof(0)) { infile >> word; I'm stuck. Should I use if statement? if( a.at(i) == a.at(i) ) a.erase(i,i); ? else { |
| Apr19-07, 09:00 PM | #2 |
Recognitions:
Dealing with text is always a complicated task in programming especially for beginners. How are the words formatted in the text file? Are they separated by a delimiter of sorts (e.g. comma, semi-colon, etc)? Or is it one word per line?
So you need to make sure that you are indeed getting your words into the vector. A straight-forward algorithm would be, using my own rough pseudo-code: Code:
WhileNot (EndofFile)
TempWord = GetNextWordFromTextFile()
ForEach (Word in Vector)
If TempWord == Word[x] in Vector
DuplicateWordTest = true
BreakForLoop
EndIf
EndFor
If (DuplicateWordTest = false)
Vector.AddWord(TempWord)
EndIf
EndWhile
| Apr19-07, 10:00 PM | #3 |
Recognitions:
Instead of a vector you should use a Hashtable, or dictionary, this will give better performance because for each word you don't have to check every previous word. For example, in C#:
Code:
string[] words = text.Split(new char[]{ " "});
Dictionary<string, bool> index = new Dictionary<string, bool>(words.Length);
foreach(string word in words){
if(index.ContainsKey(word)) Console.Write(" " + word);
else index[word] = true;
| Thread Closed |
Similar discussions for: I need to write a function that reads words from a text file and
| Flow Rate of Merging Streams | Introductory Physics Homework | 2 | ||
| Streams | Engineering, Comp Sci, & Technology Homework | 0 | ||
