Eeeeaaargh (homotopy, what else)
  • Thread starter Thread starter quasar987
The discussion revolves around a question from a final exam regarding the relationship between continuous functions and homotopy. Specifically, it asks whether the condition that the compositions of two functions with a third function being homotopic implies that the two functions themselves are homotopic.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of the homotopy condition and question the validity of the original poster's assumption. Some provide counterexamples using constant functions to illustrate that the conclusion does not necessarily follow.
The discussion is active, with participants offering various perspectives and examples. Some participants have provided counterexamples to challenge the original assertion, while others are clarifying definitions and exploring the implications of the homotopy relationship.
There is a focus on the definitions of homotopy and the properties of continuous functions. Participants are examining the implications of using constant functions and the conditions under which homotopy can be established.
quasar987
Question in my 3 hours final from 10 minutes ago that I thought about for 2 hours:
Let f,g,h:X-->X be continuous fonctions. If f o h ~ g o h, is it true that f ~ g.
Nothing convincing.
Of course not. Take h to be a "constant" function: h(x)= p for all x. Then
f o h= g o h for all f and h.
Nothing convincing.
Observe that what you just wrote is the definition of "h is a epimorphism". (in the category of spaces and maps modulo homotopy)
What does the ~ stand for?
Is homotopic to (as the title of the post implies).
You meant "for all f and g"?
And how is this possible. Let f(p)=q and g(p)=r.
And finally, even if you're right, what does this prove? :confused:
quasar987 said:
But what does this prove? :confused:
He meant f and g, and this means f and g need not have any relation to each other (other than that f(p) can be joined by a path to g(p)) so if you can find any two that aren't homotopic, you'll have a counterexample.
This is the same kind of confusion in the other thread, namely, if you are wondering whether A=>B, but you see you can get A in an almost completely generic situation, then it almost always follows that this implication is false, you just need to find one example that satisfies B and one that doesn't (and which both satisfy A, which wll follow from the genericness).
What do you mean what does it prove? It is a counter example. Since fh=gh for all f and g, you certainly can't cancel on the right, unless you think all maps are homotopic.
In my exam, I said
Let X=[0,1]u[2,3], let h be the constant function h(x)=0, let f be the identity and g(x)=x if x is in [0,1] and g(x)=x-2 if x is in [2,3].
Then (f o h)(x) = (g o h)(x) = 0 for all x, so f o h ~ g o h. And then I said, not half convinced, that f is not ~ to g.
Is that any good? It kind of ressembles what Halls of Ivy said, except he said (f o h)(x) = (g o h)(x) no matter f and g which I can't make any sense of even if my life depended on it.
Actually, I mispoke. If h is constant, the fh is constant, and gh is constant for any f,g. Let's suppose these are homotopic, i.e. the points lie in the same path component, and fh~gh. Then are you saying that you think *all* maps must be homotopic? Clearly this can't be: let f be the identity map and g be *any* map not homtopic to the identity. Surely you can think of spaces that are pathconnected (so all constant maps are homotopic), and that have two non-homotopic maps.
Is that any good?
Yeah, that sounds good.
What he should have said is this (which is exactly what matt grime also just said):
Let h be constant, with value c. If f(c) and g(c) lie in the same path-connected component of X, then f o h ~ g o h. This holds for ANY two functions f and g such that f(c) and g(c) lie in the same p-c component of X. This is a very weak condition to impose on f and g, so chances are that there are many function f and g which aren't homotopic to one another, even though f(c) and g(c) can be path-connected.
  • · Replies 21 ·
