Complex Algebra Help: Finding u(x,y) & Proving Result
The discussion focuses on solving the partial differential equations given by the relationships {\frac {{\it du}}{{\it dx}}}=y and {\frac {{\it du}}{{\it dy}}}=x to find the function u(x,y). The proposed solution is u(x,y) = xy + c, where c is a constant. The proof involves integrating the equations with respect to x and y, leading to the forms u(x,y) = xy + φ(y) and u(x,y) = xy + ψ(x). By comparing these forms, it is concluded that φ(y) and ψ(x) must be constant, thus confirming u(x,y) = xy + C, where C is a constant.
  • Understanding of partial differential equations
  • Knowledge of integration techniques
  • Familiarity with the concept of functions of multiple variables
  • Basic calculus, specifically differentiation and integration
  • Study the method of characteristics for solving partial differential equations
  • Learn about integrating factors in differential equations
  • Explore the implications of boundary conditions on solutions
  • Investigate the role of constants of integration in multivariable calculus
Students studying calculus, particularly those focusing on differential equations, as well as educators and tutors seeking to enhance their understanding of solving partial differential equations.
rsnd
I am told: [itex]{\frac {{\it du}}{{\it dx}}}=y[/itex] and [itex]{\frac {{\it du}}{{\it dy}}}=x[/itex]. Need to find u(x,y) which is a real valued function and prove the result.
Well, I think the answer is of the form u(x,y) = xy + c because the answer makes sense but how should I go about proving it?
Thanks
By integrating and reasoning logically.
[tex]\frac{\partial u}{\partial x}=y[/tex]
Therefor, integrating wrt x:
[tex]\int\frac{\partial u}{\partial x}dx=\int ydx[/tex]
[tex]u(x,y)= yx+\phi(y)[/tex]
phi(y) is kind of like the constant of integration, but we reckon that in the most general case, it may actually be a function of y. Make sure you understand why.
We can do the same with the other equation:
[tex]\frac{\partial u}{\partial y}=x[/tex]
[tex]u(x,y)=xy+\psi(x)[/tex]
Now compare the two equations. What do you conclude about the forms of [itex]\phi(y)[/itex] and [itex]\psi(x)[/itex]?
I would have done this slightly differently.
You are given that
[tex]\frac{\partial u}{\partial x}= y[/tex]
so [itex]u(x,y)= xy+ \phi (y)[/itex]
as quasar987 said.
Now differentiate that with respect to y:
[tex]\frac{\partial u}{\partial y}= x+ \frac{d\phi}{dy}[/tex]
and that must be equal to x. What does that tell you about
[tex]\frac{d\phi}{dy}[/tex]?
(I said slightly differently!)
  • · Replies 27 ·
  • · Replies 27 ·
