Grounding Cars: Why a Rubber Strip is Needed
The discussion centers on the necessity of grounding cars using a rubber strip to prevent static charge buildup from friction with air. While car tires are made of rubber and connect to the metal body of the vehicle, they do not effectively ground the car due to varying conductive properties of rubber materials. The rubber strip serves as a direct grounding mechanism, particularly noted in installations near tolling stations to protect operators from electric shocks.
  • Understanding of electrostatic discharge principles
  • Knowledge of material conductivity, specifically rubber and metal
  • Familiarity with automotive design and components
  • Basic physics concepts related to friction and charge buildup
  • Research the properties of different rubber materials and their conductivity
  • Explore the principles of electrostatic discharge in automotive applications
  • Investigate the design and function of grounding systems in vehicles
  • Learn about safety measures for operators in high-voltage environments
Automotive engineers, physics students, safety professionals, and anyone interested in vehicle design and static electricity management.
Ry122
In my physics book it says that friction between cars and air can cause a build up of charge on the vehicle's body and that's why a rubber strip is often connected from the body of the car to the ground - to ground the car.
Since the tyres which are rubber are connected to metal which is connected to the shell of the car shouldn't the tyres be able to do the same thing?
haha never heard of that rubber strip :)
I think that it's not exactly correct to generalize all rubbery materials as having the same conductive properties. Even when we speak of car tires, you'll see that there are differences in the materials used.
As for the rubber strip, I've never seen one myself, but I have seen metal strips installed before tolling stations so that the operators don't get the zap of their life... thousands of times per day ;)
See:
http://www.cartalk.com/content/columns/Archive/1994/November/11.html
13K
  • · Replies 38 ·
23K
