Pendulum Period with Free-Spinning Disk: How does it differ from a fixed disk?
  • Thread starter Thread starter anand
    Pendulum Period
The discussion revolves around determining the period of a pendulum that consists of a disk mounted on a rod, specifically examining how the period changes when the disk is allowed to spin freely compared to being fixed. The subject area includes concepts of rotational dynamics and pendulum motion.
  • Participants explore the implications of the disk's moment of inertia changing when it is free to spin. Questions arise about whether the disk will rotate while the pendulum swings and how this affects the overall dynamics of the system.
There is an ongoing exploration of the assumptions regarding the disk's behavior when free to spin. Some participants suggest that the disk can be treated as a point mass under certain conditions, while others question the implications of its orientation and motion relative to the pendulum's path.
Participants note the importance of the bearing's position and the disk's initial orientation, as well as the potential effects of external forces like air resistance, which are being set aside for the sake of the discussion.
anand
Find the period of a pendulum consisting of a disk of mass M and radius R fixed to the end of a rod of length l and mass m.How does the period change if the disk is mounted to the rod by a frictionless bearing so that it is perfectly free to spin?
torque=moment of inertia*alpha=r X F
I know how to do the first part,but I can't do the second part.What happens when the disk is free to spin?
maybe the moment of inertia changes wrt motion of pendulum? Interesting problem. Can you post the soln to first part?
If the disk is free to rotate then it will, in fact, not rotate while the pendulum is swinging. Hence for moment purposes I think it can be treated as a point mass.
Thats very interesting Dick, and I should read more carefully, I assumed it was spinning and hence had to take some average moment of inertia. So the pendulum is just falling into the energetically most favorable situation? If the disk were perpendicular to the motion of travel initially would it remain there indefinitely (ignoring air resistance)?
Assuming the bearing is at the center of mass of the disk - then there aren't any forces around that could cause a torque. If it's already spinning, I don't think that causes any complication as long as the spin axis of the disk is perpendicular to the plane of the pendulum. If it's not then it's a gyroscope and all bets are off.
Here is how I did the first part:
First find the total moment of inertia around an axis passing through the pivot.That would be 1/3 ml^2+1/2MR^2+Ml^2
The centre of mass of the system can be found,which is
C=(ml/2+Ml)/(m+M)
The component of the weight tangential to motion is (M+m)g sin(theta)
Torque is vector from origin X perpendicular component of force:
-(m+M)g *sin(theta) *C
But it is also equal to moment of inertia*angular acceleration:
(1/3 ml^2+1/2MR^2+Ml^2) * alpha
Equating the two,we get an equation for SHM,and
omega is (1/3ml^2+1/2MR^2+Ml^2)/(ml/2+Ml)g
From what you have said,the disk wouldn't spin,once the bearings are in place.Would it kind of keep pointing in the same direction,instead of being carried along with the rod?Do you mean to say that the term 1/2 MR^2 should be dropped?Please explain.
the part i struggle with is assume its a long rod and not a disk just for clarity, it seems to me there would be a big difference if the rod is within the plane of the pendulums motion vs one that is perpendicular. Just hits the ole counterintuitive nerve.
Yeah,I don't really get it either.Someone please explain.Anyway,thanks in advance.
hi
thanks
thanks
thanks
thanks
I think we have to assume that the plane of rotation of the disk is is the same as the plane of the pendulum. And then, yes, the disk will kind of keep pointing in the same direction (zero torque). Hence you can drop it's center of mass inertia (1/2mR^2) and treat it as a point mass (Ml^2).
Thanks a lot!
  • · Replies 22 ·
10K
