Static equlibrium on a diving board
The discussion focuses on calculating the forces acting on a diving board in static equilibrium. A diver weighing 550 N stands at the free end of a 3.00 m diving board, which weighs 255 N. The normal force at the support point, located 1.00 m from the end, is calculated to be 2030 N. To find the force at the end held down, participants emphasize the importance of calculating torques about different pivot points, as the torque at the fixed point eliminates the desired force from consideration.
  • Understanding of static equilibrium principles
  • Knowledge of torque calculations
  • Familiarity with forces and moments in physics
  • Ability to analyze problems involving uniform objects
  • Study the concept of torque in rotational dynamics
  • Learn about static equilibrium conditions in physics
  • Explore the calculation of forces in systems with multiple weights
  • Investigate the application of pivot points in torque calculations
Physics students, engineering students, and anyone interested in understanding the mechanics of static equilibrium in structures.
ph123
A diving board of length 3.00 m is supported at a point a distance 1.00 m from the end, and a diver weighing 550 N stands at the free end. The diving board is of uniform cross section and weighs 255 N. Find the force at the end that is held down.
In part a, I found the normal force at the support point, 1m from the end held down.
N = [550N(3m) + 255N(1.5m)]/1.0m = 2030N
Part b wants the force at the end held down. I don't really know how to approach this part, since the end held down is at my x=0m point. I found the center of mass to be 2.52m. I know the torque calculated should be about the support point.
Sum torques = N(L/3) + N(0) - W_b(L) - W_d(L/2)
where W_b = weight of the board
W_d = weight of the diver
But since the end held down is at zero, this term drops out and I'm left with what I got for the first part.
You want the distance from your pivot point to where the force is acting. Just because the end of the board is at x=0, doesn't mean that the distance to that point is zero.
Your choice of calculating the torques about the fixed point eliminates the force you want to calculate, as you discovered. The trick is shift this point to another place. Since the board is in rotational equilibrium the sum of the torques about any point needs to be zero.
9K
