Protecting Eggs with Tape and Balloons: A Scientific Approach
  • Context: High School
  • Thread starter Thread starter darthchocobo
    Drop Egg Egg drop
The discussion revolves around methods to protect an egg from impact using materials such as poster board tape and balloons. Participants explore various designs and configurations, focusing on the structural integrity and cushioning properties of their proposed solutions.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant suggests creating a pyramid or rounded pyramid structure with a heavier tip and multiple layers of balloons to maximize protection for the egg.
  • Another participant agrees that the pyramid design could work, emphasizing the importance of ensuring the egg does not bounce out of the structure.
  • A participant inquires about the technique of nesting balloons, proposing a container shaped like the egg within the pyramid.
  • One participant explains 'nesting' as inflating one balloon inside another, suggesting that if the balloons are large enough, they can accommodate the egg while providing additional cushioning.
  • Another participant builds on the idea of using two balloons, placing the egg in the center for optimal safety, and mentions adding a partially inflated balloon as a redundancy feature in case of failure of the outer balloon.
Participants express varying ideas about the design and effectiveness of their proposed methods, with no clear consensus on the best approach. Multiple competing views remain regarding the optimal configuration for egg protection.
Participants have not fully detailed the assumptions behind their designs, such as the size and type of balloons or the specific impact conditions. The discussion also lacks resolution on the effectiveness of the proposed methods.
Individuals interested in experimental design, engineering challenges, or educational projects related to physics and material properties may find this discussion relevant.
darthchocobo
Anybody know a good way to stop the force from reaching or crushing an egg using poster board tape and balloons? I was thinking bout making a pyramid or rounded pyramid and making the tip heavier and then putting multiple layers of baloons and the egg at the farthest point from impact... Any ideas?
That should work okay, as long as you make sure that it can't bounce out.
Have you considered nesting the balloons? It's not easy to do, but possible.
How do u nest? I was thinking to make a container inside of the pyramid type thingy that is in the shape of the egg.
By 'nesting', I meant that you inflate one balloon inside another. If your balloons are big enough that you can force a lubricated egg in through the neck, you can 'stack' balloons inside each other. If they're connected at the neck area, just weight the other end so they land right-side-up.
I just develop Danger's idea by using 2 balloon. The egg is in the center then in the safest condition
Thanks, Pixel; that clarifies it nicely. The only difference is that I'd have a partially inflated balloon between the two shown. That's just a redundancy feature in case the outer one breaks or the inner one stretches enough to make contact with the bottom.:cool:
  • · Replies 16 ·
32K
40K
15K
21K
