Center of mass and distance ratio
The discussion centers on demonstrating that the ratio of distances between two particles from their center of mass (CM) is the inverse of their masses. The formula for the center of mass is defined as x_{cm}={m_1\ell_1+ m_2\ell_2 \over m_1+m_2}. By setting the CM coordinate to zero, the origin of the x-axis is effectively shifted. The calculation of the distance ratios must account for the sign of one distance, which is negative due to the position of the particles relative to the CM.
  • Understanding of center of mass (CM) calculations
  • Familiarity with basic physics concepts of mass and distance
  • Knowledge of coordinate systems and their transformations
  • Ability to perform algebraic manipulations with ratios
  • Study the derivation of the center of mass formula in detail
  • Explore the implications of negative distances in physics
  • Learn about the concept of mass distribution in systems of particles
  • Investigate applications of center of mass in mechanics and dynamics
Students of physics, educators teaching mechanics, and anyone interested in the mathematical foundations of particle systems and their interactions.
kthouz
how to show that the ratio of the distance between two particles from their centers of mass is the inverse of their masses? I tried but i found a way which can be possible if only we assume that they are constituted by a same number of small particles.
Start with the definition of CM:
[tex]x_{cm}={m_1\ell_1+ m_2\ell_2 \over m_1+m_2}[/tex]
Then ask that the coordinate of the CM be zero. This is just a change in the position of the origin of x.
Then compute de ratio of distances to the CM. Don't forget that now one of the distances in negative. See why?
  • · Replies 25 ·
  • · Replies 19 ·
