Gas pressure and fluid question
  • Context: Undergrad
  • Thread starter Thread starter SoilTech
    Fluid Gas Pressure
The discussion revolves around the pressure dynamics of acetylene gas generated from a reaction between calcium carbide and water in a setup involving two Erlenmeyer flasks. Participants explore the implications of gas pressure on the movement of water through connecting tubes, safety concerns regarding acetylene pressure, and the mechanics of siphoning in this context.
  • One participant describes the setup and asks how to determine the pressure of acetylene gas in Flask A during the reaction process, particularly the pressure needed to initiate water movement through the vent tube.
  • Another participant explains that as pressure rises, water will rise in the vent tube until it reaches a maximum height, at which point the pressure is at its peak. They note that once the pressure difference becomes negative, water will continue to flow due to the siphon effect.
  • A participant mentions the conversion of water height to pressure units, indicating that 10.7 meters of water corresponds to one bar, and provides a conversion for millimeters of water to bars.
  • One participant expresses concerns about the safety of using acetylene at pressures exceeding 15 psig and seeks factual information about the pressure of acetylene gas in the flasks, especially in light of colleagues dismissing these safety concerns.
  • Another participant reassures that the method is not overly dangerous, referencing its use in acetylene lamps for speleologists and suggesting that the presence of acetone in compressed gas cylinders helps prevent explosions at higher pressures.
Participants express varying levels of concern regarding the safety of the method and the pressure dynamics involved. While some provide reassurances about the method's safety, others emphasize the need for caution and factual understanding of the pressures involved. No consensus is reached on the overall safety or efficacy of the method.
Participants acknowledge the importance of ensuring that water can circulate easily through the tubes and that pressure should build at a controlled rate. There are also references to the potential dangers of explosive mixtures of acetylene and air, as well as the implications of using acetone in gas cylinders.
SoilTech
It has been a number of years since I studied general physics and I'm looking for help on how to solve the following question. This is not a homework question, this is me trying to satisfy my curiosity regarding an application at work.
I have two 2L Erlenmeyer flasks, one flask (Flask A) contains 1.5L of water and has a stopper with two 1/4 ID tubes inserted into it. The first tube (Sample Tube) extends to a point near the surface of the water, but not below it and the top of this tube is sealed with a rubber septum. The second tube (Vent) extends all the way to a point near the bottom of the flask, well below the surface of the water and connects to the second stoppered flask (Flask B) which is empty. Again, in Flask B the Vent tube extends to a point near the bottom of the flask.
A few grams of Calcium Carbide are added to Flask A and the stopper is replaced. The calcium carbide reacts with water to generate acetylene gas and as the volume of gas increases the water in Flask A is forced through the vent tube and into Flask B and the reaction continues until the water level in Flask A is is near the bottom of the vent tube but not below it.
How would I go about determining the amount of pressure the acetylene gas in Flask A is under at a given point during this process? What is most important to me is to determine the amount of pressure required to begin moving the water up through the vent tube and into Flask B.
Thanks for the help! :smile:
As the pressure rises, water rises on the vent tube until it reaches the highest point in the tube. At this moment the pressure reaches its highest value.
After this water continue to fill the vent tube and begin to descend in flask B. The pressure diminishes. The pressure equals the difference between the limit of the water in the tube and the level of the water in flask A.
Once this difference becomes negative, the water continues to flow from A to B, even if the pressure diminishes, because of the siphon effect (see http://en.wikipedia.org/wiki/Siphon) .
I talked about pressure as height of water. You can convert this to bars, knowing that 10.7 meters is one bar, then 1 millimeter of water is [tex]9.3\,10^{-5}[/tex] bar.
I suppose that you are aware about explosive mixes of acetylene and air and how the reaction water-carbide is exothermic.
Thank you lpfr for your response. I am aware of the dangers of acetylene and air, this is in part the reason for my question. It is considered unsafe to be using acetylene at pressures exceeding 15 psig and although I realize very little pressure is required to move the water through the tubing and between the two flasks, I still have concerns about this method. I am basically trying to collect some hard facts about the pressure of the acetylene gas inside the flasks as I have had a few colleagues dismiss my concern with the safety of the entire method.
We normally use acetylene contained in a compressed gas cylinder, however this presents a problem because the acetone which the C2H2 is dissolved in within the cylinder must be scrubbed out using a H2SO4 procedure which is equally undesirable.
All the pressures that I described are valid in the case that the water can circulate easily through the tubes. They should be large enough, and the pressure should build not too fast.
This method is not too dangerous as this is how acetylene lamps of speleologists work.. Maybe you just need to buy one of those lamps?
The acetone avoids the acetylene to explode when the pressure exceeds some value (12 bars?)
  • · Replies 40 ·
  • · Replies 19 ·
  • · Replies 25 ·
9K
