Moment of inertia with varying density
The discussion centers on calculating the moment of inertia for a sphere with varying density, specifically where density is defined as a constant multiplied by the radius (d = cr). The user applied the mass element formula dm = 4π(d)r²dr and integrated to derive the moment of inertia, arriving at 2/15mr². However, other participants suggested that this result appears too low, with one participant calculating 1/2Mr² and another arriving at 4/9MR², indicating a need to verify the constant c used in the calculations.
  • Understanding of moment of inertia concepts
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of density functions in physics
  • Experience with spherical coordinates in physics
  • Review the derivation of moment of inertia for varying density spheres
  • Learn about the application of integration in physics problems
  • Investigate the implications of different density functions on moment of inertia
  • Explore the comparison of moment of inertia values for solid spheres versus hollow spheres
Physics students, mechanical engineers, and anyone involved in rotational dynamics or materials science will benefit from this discussion.
PhilosophyofPhysics
I had to find the moment of inertia of a sphere of varying density where the density is some constant times the radius.
I used the equations from here
http://hyperphysics.phy-astr.gsu.edu/hbase/isph.html
I inserted this d=cr in for the density.
For the mass I used dm=4(pi)(d)r^2dr, inserted the density, integrated and solved for c.
After substitution I the answer I got was 2/15mr^2.
Does this sound right?
The answer should be between the solid sphere value and the thin shell value, so your answer is too small. I did a rough calculation and got 1/2Mr^2.
Can you show more of your working ?
your dm element seems ok if you are taking thin shell as your differential element. I got [tex]\frac{4}{9} MR^2[/tex]. you should check whether you have got constant c correct.
  • · Replies 40 ·
