Contradiction-Contrapositive hybrid
  • Context: Undergrad
  • Thread starter Thread starter Jin314159
The discussion revolves around the legitimacy of a hybrid proof method that combines contradiction and contrapositive approaches to establish the implication P implies Q. Participants explore the nuances of these proof techniques and their interrelations.
  • One participant questions whether a contradiction-contrapositive hybrid method is valid for proving P implies Q, suggesting that showing both P implies Q_not leads to a contradiction and P_not implies Q leads to a contradiction could suffice.
  • Another participant argues against the initial claim, stating that showing P implies Q_not leads to a contradiction does not necessarily prove P implies Q, as it does not clarify what P does imply.
  • A third participant attempts to clarify the relationship between "P implies Q" and "P and Q," expressing confusion about the implications of these statements.
  • Further, a participant explains the logical equivalences involved in implications, including modus ponendo ponens and modus tollendo tollens, and how these relate to the contrapositive.
  • Another participant notes that proving P does not imply Q_not does not necessitate that P must imply Q, highlighting the complexity of the logical relationships involved.
Participants express differing views on the validity of the proposed hybrid proof method, with no consensus reached on its legitimacy. There is also confusion regarding the distinctions between implications and conjunctions, indicating a lack of agreement on foundational concepts.
Participants exhibit varying levels of understanding regarding the implications of logical statements, and there are unresolved questions about the definitions and relationships between the concepts discussed.
Jin314159
Hi folks. Long-time lurker, first-time poster. Anyways, my question regards the legitimacy of a contradiction-contrapositive hybrid method of proving.
Let's say we need to prove P implies Q. Contradiction says: If P implies Q_not leads to a contradiction, then we are done. Contrapositive says: If Q_not implies P_not, then we are done.
So a Contradiction-Contrapositive hybrid consists of first applying contradition, and then applying contrapositive. For example: To prove P implies Q by contradiction, we need to show P implies Q_not leads to a contradiction. But if we can also show that P_not implies Q leads to a contradiction, then are we done?
Is this method of proving legit?
"Contradiction says: If P implies Q_not leads to a contradiction, then we are done."
This is wrong. "If P implies Q_not leads to a contradiction" then P does NOT imply Q_not. That says nothing about what P DOES imply: in particular it does not prove that P implies Q.
"(A implies B)_not" is equivalent to "A and B_not" not "A implies B_not" as you seem to think.
In proof by contradiction we do not assume that "P implies Q_not" and then show that we get a contradiction. We assume P and Q_not and show that that leads to a contradiction. In the simplest cases the contradiction is to show that from Q_not we can arrive at P_not (which contradicts P)- that is the same as proving the contrapositive.
Finally, "If we can also show that P_not implies Q leads to a contradiction, then are we done?"
No, "P_not implies Q leads to a contradiction" is equivalent to "(P and Q_not)_not" which is the same as "P and Q" not "P implies Q".
not( P and notQ) is the same as [(notP) or (Q)] which is the same as P=>Q, assuming I can read it correctly which is by no means certain.
But the rest (of HoI's post) seems right as much as my befuddled brain can be bothered to figure out.
I'm a bit confused at the difference between "P implies Q" and "P and Q." Understanding this discrepancy will help me understand your explanation.
Actually, let me take a stab at what the difference between "P and Q" and "P implies Q" is.
P and Q means that it is possible for P and Q to both occur. For example, it's possible to be both fat and bald.
But P implies Q means that if the former is true, it's for certain that the later is true. So taking our previous example, being fat does not imply being bald.
Jin314159
From the definition of implication [symbol -> ;where p -> q is logically equvalent with (not)p OR q] can be derived the so called modus ponendo ponens and modus tollendo tollens:
If p -> q and p=true (or 1) then q=1 (true) modus ponendo ponens
If p -> q and q=false (0) then p=0 (false) modus tollendo tollens
From the modus tollendo tollens we can derive the following logical equivalence (<->):
p -> q <-> (not)q -> (not)p
This is exactly the contraposition rule you mentioned above and from the definition of equivalence results that if we prove that (non)q implies (non)p then we have also proved that p -> q.
But the fact that p does not imply (non)q [or that (not)p does not imply q] does not mean that p must imply with necessity q.
  • · Replies 26 ·
