Amplitude of Sound Waves from Two Sources at a Point
The discussion revolves around the amplitude of sound waves emitted from two sources, A and B, that are in phase. The problem involves analyzing the resultant amplitude at a point P, given the distances from the sources and the relationship between the amplitudes and phase differences of the waves.
  • Participants explore the mathematical representation of sound wave displacement and question the simplification of sine terms in relation to amplitude. There is discussion about the phase difference and its implications for the resultant amplitude.
Participants are actively engaging with the problem, questioning the validity of certain terms in the provided solution and exploring the relationship between displacement and amplitude. Some guidance has been offered regarding the interpretation of amplitude in the context of maximum displacement.
There is a noted concern regarding the dimensional correctness of the term involving 1/rA, and participants are considering the implications of the problem's constraints on their interpretations.
e(ho0n3
[SOLVED] Amplitude of Sound Waves from Two Sources at a Point
Problem. Two sources, A and B, emit sound waves, in phase, each of wavelength [itex]\lambda[/itex] and amplitude [itex]D_M[/itex]. Consider a point P that is a distance [itex]r_A[/itex] from A and [itex]r_B[/itex] from B. Show that if [itex]r_A[/itex] and [itex]r_B[/itex] are nearly equal ([itex]r_A - r_B \ll r_A[/itex]). then the amplitude varies approximately with position as
[tex]\frac{2D_M}{r_A} \, \cos \frac{\pi}{\lambda} (r_A - r_B)[/tex]
Let D(x, t) be the function that describes the displacement of the sound waves at some time t and a distance x from the source. I figure that the displacement at point P must be [itex]D(r_A, t) + D(r_B, t)[/itex] right? One thing I'm noticing is that the expression for the amplitude given in the problem statement does not vary with time. What gives?
If I look at the situation when t = 0, I get that the displacement at P is
[tex]D_M \sin kr_A + D_M \sin kr_B = 2D_M \sin \frac{\pi}{\lambda} (r_A + r_B) \cos \frac{\pi}{\lambda} (r_A - r_B)[/tex]
How in the world does the sine expression simplify to 1/rA?
This problem describes the double slit interference pattern at a point near the central maximum. The signal might vary with time, but per definition the amplitude is the maximum (minimum) strength of the resulting signal.
Interesting. However, I'm still puzzled as why the sine term simplifies to 1/rA.
I can get close :
The phase difference, [tex]\delta[/tex], between the two waves at the point P will be small under the stated conditions. Since the amplitude of the resultant at P is proportional to
[tex]\cos^2(\frac{\delta}{2})[/tex]
which under the stated conditions reduces to
[tex]\cos(\frac{\delta}{2})[/tex]
The phase difference at the point P is given by
[tex]\delta = k \Delta r[/tex]
with the wave number [tex]k = \frac{2 \pi}{\lambda}[/tex]. We therefore have that
[tex]\cos(\frac{\pi \Delta r}{\lambda})[/tex]
for the above mentioned.
I am very suspicious about the [tex]\frac{1}{r}[/tex] term in the given solution, since the dimension is then incorrect.
How do you know that? Where did you get that expression from?
You're right. Perhaps it is incorrect. I think we can safely ignore the 1/rA term.
It just hit me. The problem wants the maximum displacement, i.e. the amplitude at point P. The displacement at P is given by:
[tex]2D_M \cos \frac{\pi}{\lambda} (r_A - r_B) \sin (\pi / \lambda (r_A + r_B) + \omega t)[/tex]
and the maximum displacement or amplitude is just
[tex]2D_M \cos \frac{\pi}{\lambda} (r_A - r_B)[/tex]
Duh!
  • · Replies 19 ·
