Instantaneous velocity and friction
The discussion revolves around calculating the instantaneous velocity of a car launched down a hallway and understanding the friction involved in this scenario. Participants explore various formulas and factors that influence these calculations, including the effects of surface type and weight on friction.
  • Participants discuss different formulas for instantaneous velocity, such as v = d/t and v = u + at, while also addressing the calculation of friction using F = μN. Questions arise regarding the accuracy of these calculations based on varying conditions.
Several participants have offered different approaches to calculating instantaneous velocity and friction, leading to a range of interpretations. There is an ongoing exploration of the factors affecting these calculations, with no explicit consensus reached yet.
Participants note that the coefficient of friction can vary based on the materials in contact and that experimental data may be necessary for more precise calculations. The discussion acknowledges the complexity of accurately determining friction in different scenarios.
pineapple629
We need to know the instentaneous velocity formula for a car launched down a hallway. we also need to figure out how to calculate all the friction involved in this. please help.
The car's velocity at a certain moment [tex]t[/tex] is:
[tex]\vec V(t) = \vec V_0 + \vec at[/tex]
The car's acceleration is defined as:
[tex]\vec a = \frac{\vec \Sigma F}{m}[/tex]
In this case the only force on the motion axis (X) is the friction:
[tex]\vec a = \frac{\vec f_k}{m} = \frac{-N\mu }{m} = \frac{-mg\mu }{m} = g\mu[/tex]
Therefore the car's velocity is:
[tex]\vec V(t) = \vec V_0 - g\mu t[/tex]
Does this answer your question?
The instantaneous velocity formula for a car launched down a hallway can be calculated using the equation v = d/t, where v is the velocity, d is the distance traveled, and t is the time taken. To calculate the friction involved, we need to consider the various factors that contribute to friction, such as the surface of the hallway, the weight of the car, and the air resistance. We can use the equation F = μN, where F is the force of friction, μ is the coefficient of friction, and N is the normal force. The coefficient of friction depends on the materials in contact and can be determined experimentally. Once we have the force of friction, we can use the equation F = ma, where m is the mass of the car and a is the acceleration, to calculate the total amount of friction acting on the car. It is important to note that friction can vary depending on the speed and other external factors, so the calculated value may not be completely accurate. It is always a good idea to conduct experiments and gather data to get a more precise understanding of the friction involved in a specific scenario.
To calculate the instantaneous velocity of a car launched down a hallway, we can use the formula v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time taken.
First, we need to determine the initial velocity of the car, which can be found by measuring the speed at which it is launched. Next, we need to determine the acceleration, which can be calculated by dividing the change in velocity by the time taken. For example, if the initial velocity is 0 m/s and the final velocity is 10 m/s after 2 seconds, the acceleration would be (10 m/s - 0 m/s) / 2 s = 5 m/s^2.
To calculate the friction involved in this scenario, we need to consider the type of surface the car is traveling on and the force of the car's weight acting on it. Friction is the force that opposes the motion of an object, and it is affected by the type of surface and the weight of the object. The formula for calculating friction is F = μN, where F is the force of friction, μ is the coefficient of friction, and N is the normal force (equal to the weight of the object).
To determine the coefficient of friction, we can use the formula μ = F/N. The normal force can be calculated by multiplying the mass of the car by the acceleration due to gravity (9.8 m/s^2). Once we have the coefficient of friction, we can plug it into the formula for friction to calculate the force acting against the car's motion.
In summary, to calculate the instantaneous velocity of a car launched down a hallway, we can use the formula v = u + at, and to calculate the friction involved, we can use the formula F = μN, where μ is the coefficient of friction and N is the normal force. It is important to note that these calculations may vary depending on the specific scenario and other factors may need to be taken into consideration. It is always best to consult with a physics expert or conduct further research for a more accurate calculation.
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 28 ·
