Understanding Amps: How Can They Be Determined Without Knowing the Circuit?
  • Thread starter Thread starter Wishbone
    Electricty
The discussion revolves around how the amperage of electrical devices can be determined without knowing the specifics of the circuit they are connected to. Participants explore the implications of circuit design, voltage sources, and the relationship between resistance and current in various contexts, including household appliances and computer hardware.
  • One participant questions how amperage can be determined without knowing voltage and resistance, suggesting that circuit components affect the current drawn by devices.
  • Another participant asserts that designers of the circuit do know the internal components and configurations.
  • A participant explains that for devices plugged into AC mains, the voltage source is known and has low impedance, allowing devices to operate in parallel without affecting each other's performance.
  • Concerns are raised regarding the determination of amperage for computer hardware, emphasizing the need to know all components and the power supply to make accurate assessments.
  • One participant notes that the power rating on configurable devices indicates maximum power consumption when fully populated, linking it to the power supply's output specifications.
  • A question is posed about why adding more components increases amperage, with a participant clarifying that added resistances in parallel reduce total resistance, thus increasing current.
Participants express differing views on the ability to determine amperage without complete circuit knowledge, particularly in the context of computer hardware. While some agree on the principles of parallel circuits and power ratings, others highlight complexities that remain unresolved.
Participants acknowledge limitations in understanding how different configurations and components affect amperage, particularly when devices are moved between circuits or when additional components are added.
This discussion may be of interest to individuals exploring electrical engineering concepts, particularly those related to circuit design, power consumption, and the behavior of electrical devices in various configurations.
Wishbone
I often see on electrical devices, they say how many amps the device uses. But I wonder how can that be? if you do not know the voltage and the resistance (im guessing they do know the resistance) how can they tell you how many amps it pulls? Also doesn't it matter what components are in the circut before the device? What if the circut divides into 100 parallel resistors right before the device, won't the amperage be significantly less? And what if these 100 resistors are in series, won't the voltage then be considerably less, causing a lowering in amperage?
The question I am asking, is how can they make a determination of the amps used without knowing the circuit.
"They" designed the circuit so they do know what's inside.
And the voltage source for the type of circuits you are talking about is known, and has low source impedance. I'm assuming the devices you are asking about are ones that plug into the AC Mains power outlets in the walls, etc. All power consuming devices are plugged in parallel into this power source, so one device doesn't affect another by being in series with it. And the source resistance (or impedance) of the AC Mains is very low, so its voltage level does not droop much when a maximum load is placed on it.
Well I an see what you mean for things like TVs or Vacuum cleaners. However, for something like computer hardware, you cannot determine the amperage for a motherboard, or RAM, unless you know all other components of the computer and power supply, no? Or for a more general example, you simply cannot make any determination about the amperage of a device when you move it from one circuit to another, correct?
Ah, that's a better question. When the designers put a power rating on a configurable device like a computer motherboard with empty memory sockets, they are listing the maximum power that can be consumed by the device, when fully populated with options. If you open up your PC (with the power off) and look at the sticker on the power supply, it will list the maximum output currents that are available from the supply for its different output voltage wire harnesses. The input power label on the outside of the PC and in the PC's Owner's Manual correspond to the maximum total output power of the PC's power supply, plus some fraction due to the lost heat because the power supply is not 100% efficient in converting the input AC Mains power to its output supply rails.
Ah excellent explanation, my final question is: why would adding greater resistance (more RAM chips, video cards, or other stuff that draws power) increase the amperage, and thus bringing it to the maximum levels? How come pugging more resistance (ie. vacuum cleaner, tv) into a outlet can blow a fuse? I figure the more resistance you add to a circuit with a constant voltage source, the lower the current will be.
Because the added resistances are in parallel, thus REDUCING the total resistance as seen by the power supply.
I understand now, thanks.
