Impulse and Momentum of a crate
  • Thread starter Thread starter jjiimmyy101
    Impulse Momentum
The problem involves a crate sliding down a smooth ramp, with a focus on determining the velocities of both the ramp and the crate at a specific point. The subject area includes concepts of impulse, momentum, and conservation of energy.
  • The original poster attempts to apply conservation of momentum and energy principles but expresses concern about having too many unknowns. Participants discuss initial conditions and clarify the velocities at rest.
Participants are exploring the relationships between the velocities of the ramp and the crate, with some guidance provided on the application of conservation principles. There is an ongoing examination of the calculations and assumptions regarding directionality and values.
There is a mention of the smoothness of the ramp and the gravitational force acting on the crate, which may influence the discussion on energy conservation. The initial conditions of the system are emphasized, with both objects starting from rest.
jjiimmyy101
Question (I added a picture): The free-rolling ramp has a mass of 40 kg. A 10 kg crate is released from rest at A and slides down 3.5 m to point B. If the surface of the ramp is smooth, determine the ramp's speed when the crate reaches B. Also, what is the velocity of the crate?
This is what I did for finding the velocity of the ramp:
1) \sigma mv1 = \sigma mv2
2) mass ramp * (velocity ramp)1 + mass crate * (velocity crate)1 = mass ramp * (velocity ramp)2 + mass crate *(velocity crate)2
3) 40*Vr + 0 = 40*Vr2 + 10*Vc2
Too many unknowns?
This is what I did for finding the velocity of the crate:
1) Vc2^2 = Vinitial^2 + 2*a*(S-Sinitial)
= 0 + 2 * 4.905 * 3.5
Vc2 = 5.86 m/s
2) I can substitute this into the first equation, but I still have too many unknowns. What should I do next?
The crate is released from rest, therefore its initval velocity Vr is zero.
(Don't forget you can also appy the rules of conservation of energy, even though it's not needed in this case. There are only two kind of forces in the problem - the gravitational force, which is preservative, and the normal force which does no work since it's always perpendicular to the displacement of the objects.)
Vr is the velocity of the ramp
Vc is the velocity of the crate
Both [tex]V_R_1[/tex] and [tex]V_C_1[/tex] equal 0 since the system is at rest before it's released.
The velocity of the crate and the velocity of the ramp are in opposite directions, right?
So the equation is
0 = -40 * Vr2 + 10 * Vb2 and since Vb2 = 5.86 m/s
Vr2 = 1.465 m/s in the opposite direction of the crate. Is it right?
I would think so, unless you made a mistake in some of the calculations. The way is correct.
thank-you
  • · Replies 23 ·
10K
