What is the proof for du = f'(x) dx in substitution method for integrals?
  • Context: Undergrad
  • Thread starter Thread starter Sleek
    Confused Dx
The discussion revolves around the equation du = f'(x) dx, commonly encountered in the substitution method for integrals. Participants express confusion regarding the validity and interpretation of this equation, particularly in relation to the notation of differentials and the process of substitution in calculus.
  • One participant questions the legitimacy of the step from du/dx = f'(x) to du = f'(x) dx, expressing discomfort with the cancellation of notation.
  • Another participant argues that the equation du = f'(x) dx is not strictly correct, suggesting it is a shorthand for a more complex explanation involving the change of variable theorem.
  • A different viewpoint suggests that while dy/dx is not a fraction, it can be treated as such under certain conditions, leading to the use of differentials in calculus.
  • Some participants emphasize that dy and dx are differentials that do not have numerical values by themselves, and their treatment as fractions is a convention that aids in understanding calculus.
  • One participant mentions that the use of du = f'(x) dx is a common shorthand that may lead to confusion, but it is widely accepted in practice.
  • Another participant points out that the concept of differentials extends beyond just substitution in integrals and is a well-defined mathematical object.
  • There is a mention of a professor's surprise at how u-substitution is taught, indicating differing pedagogical approaches to the topic.
Participants express a range of views on the validity and interpretation of the equation du = f'(x) dx. There is no consensus on whether the equation is correct or merely a useful notation, and the discussion remains unresolved regarding the foundational understanding of differentials.
Some participants note that the treatment of differentials and the cancellation of terms in calculus can lead to confusion, particularly for those new to the concepts. The discussion highlights the limitations of using shorthand notations without a rigorous foundation.
This discussion may be of interest to students learning calculus, educators exploring different teaching methods, and anyone seeking clarification on the use of differentials in integration techniques.
Sleek
Hello,
While solving integrals using substitution method, we often come across this,
if u = f(x), du = f'(x) dx
I would like to know if there exists a proof for the above equation. The problem is, I am totally dissatisfied by the explanation provided to me in the classes. During the derivatives classes, we were told that in case of (dy)/(dx), it actually means (d/dx)y, where (d/dx) stands as a notation, as opposed to dy being divided by dx.
The way the folks at my classes used substitution in the integral classes was,
let u = f(x)
diff. both sides w.r.t. x
du/dx = f'(x)
thus du = f'(x) dx [Multiplying by dx on both the sides]
But the last step's explanation seems to be too weird to me. How can a part of a notation be canceled off one side? Or is my understanding of the notation in the first place itself is wrong?
Please help me shed some light on the understanding of this dilemma I am facing.
Technically, what you're saying is wrong. du is not f'(x)dx.
Where this comes from is when you prove the fundamental theorem of calculus you get a corollary that says this: g(b)=d, g(a)=c.
[tex]\int^d_cf(g(x))g'(x)dx=\int^{g(b)}_{g(a)}f(g(x))dx=\int^{g(b)}_{g(a)}f(u)du[/tex]
where u=g(x). So from comparing the lhs and the rhs it's tempting to say that g'(x)dx=du.
Thanks for the insight. The problem is, " du = f'(x) dx " is not something that I've assumed. Its currently being used in my class notes. Moreover, after searching various online sources, the reason for similar steps of substitution, "du = f'(x) dx ". Example of this would be: http://archives.math.utk.edu/visual.calculus/4/substitutions.3/. If you view the first sum, the reason for the resubstitution is given by the above equation I mentioned. The only reason I managed to find for that step is, "By DefN of Indefinite Integrals".
But I should thank you for the information you provided.
Regards,
Sleek.
You should regard the whole "du = f'(x) dx" buisiness as just a simplified notation for the "real" change of variable theorem evoked by our friend ZioX.
How it really works is that we look at the integrand of the integral and we ask... is there a function u(x) and a function f(x) such that the integrand is actually given by f(u(x))*u'(x) ?
So we start trying things; we say, ok let u(x)=... Then, du/dx=... If it works. That is to say, if there is indeed an f such that the integrand can be written f(u(x))*u'(x), then it means that we can switch the form of the integral to the one on the far right in ZioX's post. And what we notice is that u'(x)dx was actually replaced by just du.
So the net effect of all this was to change u'(x)dx by du. So why not immediately just abuse the weak damsel in distress that is the differential 'd' notation and write directly du=u'(x)dx instead of du/dx=... the first time we introduce the u substitution.
God, was that readable?
dy and dx are called differentials.
[itex]\lim_{\Delta x \to 0} \Delta x = dx[/itex] and similarly for dy.
Therefore dy/dx can be thought of as the ratio of 2 infinitesimal changes. That is why dy and dx mean nothing by themselves. Infinitesimals do not have numerical values. The ratio may. The only reason we can pretend dx and dy actually mean things by themselves, as if dy/dx is a fraction, is because by the definition of the derivative, it is the limit of a fraction.
My post would end well attaching quasars post to it :)
You are very correct that "dy/dx" is NOT a fraction. When we first define the derivative, we do NOT define "dy" and "dx" separately. However, it is true that dy/dx is the limit of a fraction and so can be "treated" like a fraction. That is, the chain rule, dy/dz= (dy/dx)(dx/dz) cannot be proved by saying "just cancel the dx's"! But you can prove it by going back before the limit and canceling the corresponding things there. That is, again, although dy/dx is not a fraction, we can always treat it as if it were.
That's why, in most calculus textbooks, after we have defined the derivative as a "limit of fractions", we define the differentials, dy and dx, separately: by declaring that "dx" is a symbol and then dy by dy= f'(x)dx. Thus, there is no "assumption" or "proof" that dy= f'(x)dx- it is a definition- of dy.
du=f'(x)dx is, despite the fact that it works fairly well, strictly speaking not correct. OK, we all use it and it gets results, but it's really just a shorthand for a more complete explanation.
Without resorting to integral formulae, you can do the following to justify the construction.
You have u=f(x). First, let x=x(t), in other words, x is now a function of another variable t. With a little thought, you can now see that u is also a function of this new variable.
u=f(x(t))
Now differentiate u with respect to t
[tex]\frac{du}{dt} = \frac{df}{dx}\frac{dx}{dt}[/tex]
[tex]\frac{du}{dt} = f'(x(t))\frac{dx}{dt}[/tex]
Now many would say that the dt's cancel(they don't) and you get du=f'(x(t))dx or du=f'(x)dx if you make x an independent variable again.
But the dt's do not cancel. People have invented entirely new mathematical formalisms in order to be able to cancel or just get rid of those dt's in this way, but since we're not dealing with such formalisms, we have to leave them in. (They're inseperable from the upper d anyway.)
In conclusion you're supposed to use
But everyone uses
[tex]du = f'(x)dx[/tex]
for short. Unfortunately the shorthand has led to a lot of confusion, which is why the original question was asked.
You shall all listen to HallsofIvy. [itex]dy[/itex] is a well defined mathematical object called differential, and it goes beyond the change of variables method or integrals. There is a tight theory regarding this objects and is more than correct to write [itex]dy=f'(x)dx[/itex].
But a "symbolic" object rather than a "real" object in much the same way that "[itex]\nabla[/itex]", while not a "real" vector is a very useful object!
The real strength of "differentials" comes in differential geometry where they are very strictly defined.
We had a professor come from Bulgaria, she is very friendly and teaching-oriented, but when she saw how we teach "u-substitution" for change of variables under the integral sign she was shocked.
Thanks for all of your replies. I can now better understand what happens during these substitutions. It has cleared most of my doubts.
Thanks again!
Regards,
Sleek.
I have traumatic experience on this stuff. If I was a dictator, infinitesimal differentials would be forbidden by the law. Those infinitesimals are often defended for their intuitive value, but my lecturer at least only nearly attempted to confuse us as much as he could, when explained about these differentials. Potential for abuse is huge.
Anyway, just in case somebody who's still learning the basics happened to see those equations, I must correct them. [tex]\lim_{\Delta x\to 0}\Delta x = dx[/tex], is not correct, but [tex]\lim_{\Delta x\to 0}\Delta x = 0[/tex] is.
Ahh...define dx in terms of delta x for me then? I know the rigourous way to think of them, but this guys a newbie, give him some intuition.
You don't. dx is not define "in terms of delta x" (although some texts use "dx" when they should use delta x). If you think of "dx" as an infinitesmal then delta x is approximately dx.
"dx" is a symbol representing an infinitesmal. dy is then defined as f'(x)dx.
Notice the difference between 'an infintesmal' and 'representing an infintesmal'! If you are going to think of dx as being an infinitesmal, then you had better give a rigorous definition of "infinitesmal". As long as you are thinking of dx as representing an infinitesmal, you don't have to!
  • · Replies 22 ·
  • · Replies 19 ·
