How Do Light Frequencies Combine to Create New Colors?
The discussion revolves around the combination of light frequencies and how they create new colors, exploring both theoretical and practical aspects of color mixing in light and pigments. Participants inquire about equations for calculating resultant frequencies from mixtures of light and the implications for color perception.
  • One participant questions the existence of a simple equation for mixing light frequencies, suggesting that while spectra can be added or subtracted, frequencies cannot be treated like whole numbers.
  • Another participant notes that perceived colors do not correspond to single wavelengths, emphasizing the complexity of how our eyes and brains interpret mixtures of light.
  • A participant raises the issue of how many colors the human brain can differentiate, questioning the limits of color perception.
  • Some participants discuss the differences in color perception when mixing light versus pigments, indicating that the context (e.g., surrounding colors) affects the perceived result.
  • One participant mentions the principle of superposition in electromagnetic waves, stating that combining waves does not yield new frequencies under normal conditions.
  • Another participant introduces the concept of sum and difference frequency generation in nonlinear media, explaining that certain conditions must be met for new frequencies to emerge.
  • There are inquiries about the physical principles behind the equations for frequency combinations, with references to nonlinear optics and specific materials that exhibit these properties.
Participants express differing views on how light frequencies combine and the implications for color perception. There is no consensus on the existence of a straightforward equation for calculating resultant frequencies, and the discussion remains unresolved regarding the complexities of color mixing.
Limitations include the dependence on definitions of color perception, the complexity of human vision, and the specific conditions required for frequency generation in nonlinear media. The discussion does not resolve the mathematical or physical claims presented.
JPC
hey
i am wondering, what's the equation to find the result equivalent frequence of a mixture of two other different light frequences in same proportions ?
(like if u have one red torch , and one blue torch , and u aim the light of each on the same zone)
or is the result color not equivalent to anyone frequence ?
and now as for if u have dots that reflect let's say only one very short interval of frequence. Let's say there are two sorts of these dots , and let's just asume that the first reflects a big majority of x frenquence and the other of y. on a picture u have a distributed mixture of these two dots,
how can u calculate the result equivalent frequence ?
or in the result color not equivalent to anyone frequence ?
Science news on Phys.org
Please do not use chat talk.
To be honest I don't think you can mix frequencies to get a simple equation. My understanding is that you can add and subtract spectra from each other but you cannot add and subtract frequencies the way you add and subtract whole numbers (5 + 5 != 10). For example, mixing pure red light (700nm) with pure blue light (400nm) does not produce pure yellow (550nm), even though it looks like it does. You'll get an interference pattern where most of the wave appears to be 550nm, but with little bits of noise all over the wave.
Reversing the process to go from an interference pattern to seeing the component waves is called a "Fourier Transform"
Most perceived colors do not correspond to single wavelengths or frequencies. The color that we perceive when a mixture of wavelengths enters the eye depends on how the rod or cone cells in the retina respond to it, and how our brains interpret the resulting signals. I don't know much about the physiology of color vision, but I do know that it's rather complex.
Hum for the first case,
there's already infinite single wavelength that are visible
and now infinite ways to assemble single wavelength to make different colors
but how many different colors our brain can make us see ? i mean, does our brain see the difference between wavelength 550 and 550 + (1 / 10^99). Hum , must ask in the biological section of the forum
but for the second case
Doesnt it rather have to do with ourselves. If we had far more pixels in our vision, we would see images printed by our printers differently.
Because, every sensitive cell in our eyes must make up one color. I don't know how it decides of the result color. Well for that i should ask in the biological part of the forum
How many colors can you see? Bare minimum, at least 65536. I know that because I can tell right away when a video game is running in 16 bit instead of 32 bit color.
not exactly rigorous reasoning. you haven't shown that after pruning the 4294967296 colors down to 65536, that you can differentiate every one of the 65536 colors that remain. if there are sufficiently indifferential colors remaining, some of those can be replaced with colors you had missed after the pruning. suppose you went from 4294967296 to 4294967295 colors and the color that was culled was one of them that you liked and missed, would you say that you can see 4294967296 colors? i
t's a matter of perceptual modeling and bit allocation.
JPC said:
hey
If you have red and green torches your vision might say the zone was red, orange, yellow, yellow-green or green depending on how bright each torch was.
There is a kicker here.
For example, if you change the surrounding area of the zone from black to white then "yellow" would change to brown.
Nothing simple here.
Red and blue torches would make the zone magenta or purple hues.
The results of combining two colors of paint and the same two colors of light beams is different. So the color you see would depend on if the dots(pixles) were on a display monitor or printed on paper. The count of x dots vs the count of y dots changes the color and the color of the area surounding the dots also changes the color.
No, you won't.
Even the bandwith of a laser, a relatively monochromatic source is somewhat more than this.
How much change is required to see a different color probably varies considerably over the visible spectrum.
The eye's color receptors don't overlap evenly.
Radiometrically speaking, e/m waves obey the principle of superposition and you cannot get any new frequencies by combining two (or more) e/m waves.
Claude.
Claude.
In free space then ok.
AFAIK If the e/m waves encounter the appropriate medium then they can mix and generate the standard sum/difference frequencies.
For example, mixing red light (700nm) with blue light (400nm) would produce 1100nm and 300nm.
Neither of which is remotely in the visible range.
but where u got the equation :
frequency x
frequency y
result : x-y and y-x
whats the principle , the physical explanation ?
frequency x
frequency y
NoTime refers to sum and difference frequency generation which can occur in a chi^2 nonlinear medium. Normally, in the linear regime, the polarisation of an atom and the applied electric field both oscillate at the same frequency. In the nonlinear regime, additional frequency components are introduced into the oscillation of polarisation (i.e. the oscillation of the electron about its parent nucleus) by virtue of the fact that polarisation no longer varies linearly with the applied field (this is where the nonlinear comes from).
All media are nonlinear to some extent, but only media with certain crystalline structures will exhibit chi^2 nonlinearity. Lithium Niobate and BBO and two very commonly used chi^2 media.
Sum and difference frequency generation requires a high-powered, coherent source (i.e. a laser). In addition, the nonlinear medium itself has to be aligned very precisely to achieve significant generation of new frequencies. Suffice to say, that unless you are a laser specialist, or engage in some form of research with lasers or optics, you are unlikely to ever witness this effect first hand, at least until laser tvs come out.
Claude.
  • · Replies 207 ·
16K
  • · Replies 40 ·
  • · Replies 17 ·
