Practical meaning of simultaneity calculations?
The discussion revolves around the practical implications of calculating simultaneity for distant events, particularly in the context of relativity and causality. Participants explore whether simultaneity matters if events are not causally connected, and how different inertial reference frames affect the perception of simultaneity.
  • Some participants question the practical necessity of calculating simultaneity, arguing that if events are not causally linked, their simultaneous nature may not matter.
  • Others propose that simultaneity is crucial for understanding concepts in special relativity (SR), particularly regarding faster-than-light (FTL) communication and its implications for causality and time travel.
  • One participant emphasizes the importance of simultaneity in applications like GPS navigation, linking it to the empirical validation of relativity.
  • Another participant discusses the need for a coordinate system to apply Maxwell's equations, suggesting that simultaneity calculations are essential for maintaining the equations' standard form.
  • Some contributions highlight the distinction between events viewed in different inertial frames, noting that simultaneity can vary depending on the observer's frame of reference.
  • There are mentions of specific mathematical formulations for determining simultaneity, with references to Einstein's work and the implications of different reference frames.
  • One participant expresses confusion about the calculations involved in simultaneity, indicating a need for clarification on the topic.
Participants express a range of views on the significance of simultaneity, with no clear consensus reached. Some argue for its practical importance in physics, while others question its relevance when causality is absent.
Some participants reference Einstein's writings and mathematical formulations related to simultaneity, indicating a reliance on specific definitions and criteria that may not be universally accepted. The discussion includes varying levels of understanding among participants, from advanced concepts to more basic interpretations.
This discussion may be of interest to those exploring the implications of relativity in physics, particularly in relation to simultaneity, causality, and their applications in technology such as navigation systems.
Ookke
Is there any practical reason for calculating simultaneity of distant events?
Two events either are causally connected or not, and there is nothing relative about this. If a cause-effect link doesn't exist, does it matter if the events are calculated to be simultaneous from a certain point of view?
simultaneity
I think you should be more specific explaining what you mean by calculating simultaneity. We say that two events are simultaneous in a given inertial reference frame if they are characterized there by the same time coordinate and by different space coordinates. The two events could be or not in a causal relationship and we have a criteria for doing that.
Relativity becomes involved if we consider the same events form another inertial reference frame where they could be simultaneous or not.
Are there more questions?
In one regard it is very important conceptually. If you accept the predictions of SR and consider a device capable of transmitting information (or moving) faster that speed c, then in the frame where the two events (transmission and reception) are simultaneous the transmission occurs at infinite speed. Furthermore there must then be another inertial frame where the signal or object is actually traveling backward in time.
So either time-travel is possible or FTL causality is Impossible. They are qualitatively one and the same thing in SR.
The practicality of it all is that through correct understanding of empirically validated theory one can better predict the behavior of physical systems.
Relativity of simultaneity is one inseparable component of an imminently useful theory. Accurate GPS navigation is one imminently useful practical application of that theory.
Regards,
James
Note that there are many distant events
which are not causally connected to an event O on your worldline
but can influence events in the future of O.
With that knowledge, one might wish to somehow prepare those events to influence a particular event P (or set of events) in the future of O... i.e. prepare "initial data" for an "initial value problem".
bernhard.rothenstein said:
Relativity becomes involved if we consider the same events from another inertial reference frame where they could be simultaneous or not.
bernhar.rothenstein, were these words of yours contradicting Einstein's?
In Section 9 of the late Dr. Albert Einstein’s book Relativity, Eintein said: "People traveling in this train will with advantage view the train as a rigid reference-body (co-ordinate system); they regard all events in reference to the train."
Einstein's words meant to me: observers in their own inertia reference frame consider events in their own frame, not events from another frame.
Suppose you have a robotic spacecraft that you need to make a course correction burn. How would you make that happen without simultaneity calculations?
Yes. If you want to use Maxwell's equations for electromagnetism, for instance, you have to set up a coordinate system to define the value of "coordinate time" of an arbitrary event.
Furthermore, you have to use some sort of isotropic (Einsteinian) clock synchronization for Maxwell's equations to have their usual form - i.e. you can't assign time arbitrarily to events if you want Maxwell's equations to have their usual simple form, you have to assign them isotropically. Hopefully you can see why from a simple plausibility argument - Maxwell's equations give a constant speed of light in all directions, so if you don't chose your coordinates isotropically, they can't possibly work.
In general, coordinate systems are just too useful to get rid of, so one winds up with a notion of "coordinate time". However, I think you are correct to downplay the physical significance of coordinate time - to get philosophical for a bit, it's a human creation, not part of an observer-independent "reality".
simultaneity
In any case. What I say is: Consider events E'(1)[x'(1),y'(1),t'(1)] and E'(2)[x'(2),y'(2),t'(2)] detected in I i.e in one and the same reference frame! Detected from I the two events are separated by a time interval
t(2)-t(1)=g[t'(2)-t"(1)+V[(x'(2)-x'(1)]/cc]
an equation which enables us to find out the conditions under which the two avents are or are not simultaneous in I. That is all. Is there some thing in conflict with Einstein?:rolleyes:
simultaneity
Please explain me in what consists the calculation we should make? In the reference frame attached to the spacecraft or in the reference frame relative to which it moves?
I am sorry, I cannot understand your meth. I am a hobby reader, not a physics student. Let me show you what was my understanding of the simultaniety problem. To me, it is a simple Eucliden geometric problem.
Events E and E' consitute two points. Two points can always be joined by a straight line like this (Euclidean):
E_________________________________________E'
If something simultaneously departs from either end at a constant speed, say c, then they will always reach the midpont simultaneously.
Such was my understanding of the simultaniety probem, regardless from what reference frame you consider it. That is, simultaniety is absolute, not relative.
Please tell me is there anything wrong with my understanding.
This is a different situation--the observer is at the midpoint.
('midpoint' of what?)
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 51 ·
  • · Replies 127 ·
10K
  • · Replies 21 ·
  • · Replies 35 ·
  • · Replies 89 ·
10K
