How was the Planck length (or time) calculated?
The discussion focuses on the origins and calculations of the Planck length and Planck time, exploring theoretical predictions and the possibility of experimental measurement. Participants delve into the implications of these concepts within quantum mechanics and general relativity.
  • Some participants inquire about the theoretical predictions for the existence and values of the Planck length and time, questioning whether they can be experimentally measured.
  • One participant discusses the implications of measuring particles at scales smaller than the Planck length, referencing the uncertainty principle and the challenges of localization in quantum mechanics.
  • Another participant provides mathematical expressions for the Planck length and time, indicating their dependence on fundamental constants such as the gravitational constant (G), reduced Planck's constant (ħ), and the speed of light (c).
  • A later reply elaborates on the derivation of the Planck mass and its relationship to the Planck length through dimensional analysis, suggesting a connection between energy and length scales in quantum mechanics and gravity.
  • One participant notes that in natural units, the Planck mass is the reciprocal of the Planck length, highlighting an interesting relationship between these quantities.
Participants express varying levels of understanding and interest in the calculations and implications of the Planck length and time. There is no consensus on the ability to experimentally measure these quantities or on the clarity of their theoretical foundations.
Some participants express confusion regarding the relationship between the uncertainty principle and the Planck length, indicating that further clarification may be needed. The discussion also reflects a range of mathematical approaches and interpretations without resolving the complexities involved.
Chen
Can anyone please shed some light on how the Planck length or Planck time were found? I understand why they have to exist, but what predicts their values? Is it even a prediction or can we actually calculate the Plank length with experiment?
Thanks,
If the measuring device used to make the measurement
of the particle's position is smaller in dimension than the Planck
scale (i.e. Planck length), would the Uncertainty relation still apply.
Sure.
What effect would such a device have on the outcome of the
experiment?
Now, that's a harder question! Consider first that the Planck
length is about
0.000000000000000000000000000000004 cm.
(I think scientific notation packs less of a punch than regular
notation sometimes.) So it's going to be a problem *making* a
device which does this -- but of course we can just do a
gedanken experiment for free instead! So what happens, in
theory?
Suppose we're interested in localizing an electron (or other
massive particle of spin 1/2). Then the relativistic wave
equation we might try is the (single-particle) Dirac equation.
It's not too difficult to squeeze an electron down to the
size of its Compton wavelength, which is about
0.00000000004 cm.
However, if we squish it down past that then negative-energy
components start appearing! Even in the one-particle theory,
localizing the electron beyond its Compton wavelength
requires some *positron* excitation to do the trick.
This is a hint that the single-particle theory isn't right
either. We need to use quantum field theory to describe such
a tightly enclosed electron! In the QED description, extra
positrons and electrons will start appearing whenever we try
to localize beyond the Compton wavelength. (This doesn't
violate any conservation laws, because whatever is doing the
localizing is interacting with the electron somehow, so the
apparatus picks up recoil and things like that.)
I'm afraid you went right over my head. What does the principle of uncertainty have to do with Planck length?
What I'm asking really is: What predicts the existence of Planck length?, Does anything predict its value?, and Is it possible to measure the Planck length experimentally, thereby validating the prediction (if it exists) of its value?
The Planck length is:
[tex]\sqrt{\frac{G\hbar}{c^3}}[/tex]
The Planck time is:
[tex]\sqrt{\frac{G\hbar}{c^5}}[/tex]
And that's because...?
First, consider the smallest energy x length that you can have, which is dictated by our knowledge of quantum mechancs:
[tex]\hbar c[/tex]
Now set that equal to the gravitational energy to get it in terms of the gravitational constant:
equation 1 [tex]GM^2=\hbar c[/tex]
solve for M and you get the Planck mass:
equation 2 [tex]M = \sqrt{\frac{c}{G\hbar}}[/tex]
The Planck length can then be found with a little dimensional analysis:
[tex]GM^2[/tex] has units of length x energy (M is Planck mass, G is gravitational constant)
[tex]Mc^2[/tex] is units of energy (M is again the Planck mass)
and from the equations 1 and 2 you will see that:
[tex]GM^2 = \hbar c[/tex]
and
[tex]Mc^2 = c^2 \sqrt{\frac{c}{G\hbar}}[/tex]
And from that you can see that:
[tex]Planck Length = \frac{GM^2}{Mc^2}=\frac{\hbar c}{ c^2 \sqrt{\frac{c}{G\hbar}}}= \sqrt{\frac{G\hbar}{c^3}}[/tex]
You can do a similar calculation to find the Planck time.
(EDITED to fix a few mistakes)
An interesting side note is that, in natural units, where:
[tex]\hbar = c = 1[/tex]
The Planck mass is just the reciporical of the Planck length.
[tex]L _{planck} = \frac{1}{M _{planck}}[/tex]
  • · Replies 40 ·
  • · Replies 35 ·
