What are the oxidation numbers in [Re2Cl9]2- and how can it exist?
  • Thread starter Thread starter kankerfist
    Oxidation
The discussion revolves around the oxidation numbers in the complex ion [Re2Cl9]2- and the conditions under which it can exist. Participants explore the implications of oxidation states in redox reactions and the nature of bonding in this molecular structure.
  • Some participants express confusion about how [Re2Cl9]2- can exist, noting that certain arrangements can lead to varying oxidation numbers for the same atom.
  • One participant suggests that it is possible for atoms to have non-integer oxidation states, referencing carbon monoxide as an example of unusual bonding scenarios.
  • Another participant proposes that the bond order of rhenium could be 3.5, questioning if this could explain the oxidation state in the complex.
  • A participant emphasizes that oxidation numbers are merely an accounting tool and may not reflect actual chemical properties.
  • There are attempts to balance a redox equation involving [Re2Cl9]2-, with discussions on identifying oxidation and reduction half-reactions based on oxidation states.
Participants do not reach a consensus on the oxidation numbers or the existence of [Re2Cl9]2-. Multiple competing views and interpretations of oxidation states and bonding exist throughout the discussion.
Some participants mention the complexity of determining oxidation states due to potential non-integer values and the nature of bonding in transition metal complexes, indicating that assumptions about oxidation states may vary based on different interpretations.
kankerfist
Sorry about no latex, when I try using latex my formulas just wind up as a link
that says "LaTeX graphic is being generated. Reload this page in a moment."
Anyway, I was trying to balance a redox equation and I am completely stumped
as to how:
[Re2Cl9]^2-
can be possible. I'm aware that some arrangements can cause the same atoms
in an ion to have different oxidation numbers, but I can't seem to figure out how
that molecule can exist under any arrangement. Any hints would be appreciated
Chemistry news on Phys.org
as to how:
[Re2Cl9]^2-
To help with latex, I've seen that message when i try to preview a post but if i actually make a post then it will show up. Sometimes I make an error in my latex and i can just edit it real fast. Just try to post some latex and not preview see if that works.
unless you get this error then you really did something wrong
[tex]\LATEX[/tex]
Ok, I'll test it by quoting someone that used it sucessfully.
[tex]^{33}_{17}Cl^{16}\xrightarrow{n,n}~^{31}_{15}P^{16 }+~^4_2He^2[/tex]
There You Go. Now see if you can edit your first post with some good code!
Im looking forward to your work!
Edit: You the man
[tex]{ReCl}_5} + {{H_2}O}[/tex]
[tex]{Re_2}{Cl_9}^{2-} + {ReO_4^-} + {Cl^-} + {H^+}[/tex]
as to how:
[Re2Cl9]^2-
It's possible for atoms to have a charge that isn't a whole number, or the number can be very different from what is expected. For example, what is carbon monoxide, CO? Does the oxygen have 4 bonds? Does the carbon have 2 bonds? Do they compromise to make 3 bonds each? (edit: I looked it up and yes they make 3 bonds each).
The number of bonds between atoms or groups of atoms is called the Bond Order.
From that link "A good example of this is bonds between carbon in the molecule benzene where the delocalized molecular orbitals contain 6 pi electrons over six carbons essentially yielding half a pi bond. Together with the sigma bond the bond order is 1.5"
Is it possible that Re has a bond order of 3.5? Sure, why not? :smile:
Ok, finally figured it out above. I am trying to balance this equation, and in order to break it into half reactions, I need to know the ox #'s of each atom to see which is the reduction half and which is the ox half. If the Re is 3.5 like you say, then am I on the right track that the oxidation half reaction is:
2 ReCl5 + 3e- --> [tex]{Re_2}{Cl_9}^{2-}[/tex]
edit: sorry, I mean reduction half
The best approach is to assume that oxidation numbers are just an accounting device and they don't refer to any real chemical property.
  • · Replies 18 ·
23K
