Standing waves in a microwave oven
The discussion revolves around the experiment of detecting standing waves in a microwave oven by observing the melting patterns of food items placed inside. Participants explore the effectiveness of this method, the design of different microwave ovens, and the implications for understanding wave behavior in this context.
  • One participant describes their experience with the experiment, noting random scorch marks rather than a clear pattern, suggesting that the design of the microwave may affect the results.
  • Another participant points out that not all microwaves use a rotating fan to randomize waves, as some have a turning table, which could influence the detection of antinodes.
  • A different participant mentions that their microwave does not have a turning deflector, implying that it could be more suitable for the experiment.
  • One participant suggests that the expected spacing of antinodes should be around 6.5 cm based on the frequency of 2.45 GHz, but acknowledges that the angle of the microwaves could affect this spacing.
  • Another participant shares their results from a similar experiment using wet cardboard, noting that while the pattern was not as clear as hoped, the spacing observed was consistent with theoretical predictions.
  • There is a discussion about the quantum explanation of light behavior, with one participant expressing difficulty in reconciling quantum mechanics with classical explanations.
  • Another participant argues that microwaves can be understood without quantum mechanics, relying instead on Maxwell's equations.
Participants express a range of views on the effectiveness of the microwave experiment and the underlying physics, with no clear consensus on the best approach or interpretation of results. Some agree on the potential for observing patterns, while others highlight the variability in microwave designs and results.
Participants mention various designs of microwave ovens, including the presence or absence of rotating components, which may affect experimental outcomes. There are also references to the complexity of explaining quantum phenomena, indicating a reliance on different models and assumptions.
This discussion may be of interest to individuals exploring experimental physics, wave behavior, and the intersection of classical and quantum mechanics, particularly in the context of everyday applications like microwave ovens.
bdrosd
Has anyone out there actually tried the kitchen experiment of placing a continuous line of meltable food (i.e. marshmellows/chocholate/cheese etc.) across the bottom of a microwave oven in hopes of finding the antinodes of a standing wave by looking for regions that melt while the rest of the line remains solid? I have, and while I did find random schorch marks, there was by no means a regular pattern of them (as you would hope from a standing wave). It seems to me that the experiment is doomed since the incoming waves are "bounced" first off a rotating fan blade to somewhat "randomize" the waves so that there are not going to nodes and antinodes. What puzzels me is that I still see this experiment on the Web as a way to determine the speed of light from this kitchen appliance. Am I missing something?
Science news on Phys.org
Not all ovens use a rotating reflecting thing to randomize nodes. Some use a turning table (to turn the meat). In mine, there is a switch that allows stop the table turning.
lpfr, I'm not an expert but I believe that they do all have the defecting fan in addition to the rotating table.
Neither me. But I know that in catalogs you have (at least had) the choice between models with each system.
I have opened mine (longtime ago) and I assure you that it do not has a turning deflector.
Well then, your microwave oven would be ideal to check out how well you can detect the antinodes. The spacing should be ~6.5 cm (frequency=2.45 GHz). I cut out a piece of cardboard to fit the inside cavity and then completely covered it with thin slices of American cheese. As I said, I got just random burn marks but from yours I would expect burn "stripes" equally spaced. I suppose if the direction of the microwaves is not parallel to the cardboard then lamda/2 (~6.5 cm) need not be the spacing. In any event, do you have plans to run the experiment?
I have to obtain my wife's permission. It is her oven! But maybe...
I'll be waiting for results with bated breath
lpfr, I just realized that we traded a few responses a few weeks ago regarding reflections of light from smooth metal surfaces. I was attempting a quantum explanation in terms of photons; you had a classical E/M explanation. It seems to me that both approaches have to work, but if the light intensity is low enough then you have to consider the "beam" of light as composed as individual photons. Any thoughts on that approach?
Relax!
I just did the experience. I just heated a wet cardboard and observed the places where it dried faster. The pattern of dry spots was not as clear and beautiful as I hoped. But the distance between dry spots was about 6-7 cm. Assuming that this is half a wavelength, this gives a frequency of 2.3 GHz which is a good value (and far better than my expectations).
Wet cardboard, that's a good idea. Could you describe the "pattern", were there stripes, or was it linear array of spots? When I did it I was looking for the 6-7 cm spacing and I found it, but I doubt it would have convinced a skeptic
It is not easy to explain why a photon behaves in the same way as a wave. You have to say that the photon behaves as if it takes all possible paths. But this assumption is not part of quantum mechanics postulates. It is a "parachuted" assumption to explain the unexplainable.
I'm no good in quantum mechanics. It hurts my intuition. Then I do not try to explain the entire world in quantum mechanics terms. I use QM only when classical mechanics don't work. This is usually the way physicist work. They take each time the simplest model that explains a phenomenon. May be it is commodity or lack of masochism or, as in my case, ignorance.
I would have liked a checkers board. But no, there where stripes, but they do not have all the height (the cardboard was vertical about the center of the oven). And they where not regular over the surface.
But there are hundreds of modes in a cavity far greater than wavelength and the one I saw is not the prettiest.
Years ago I was using an electron microscope (transmission type) when I realized that the current of the electron beam was such that electrons were traveling through the sample one at a time. This makes it difficult to explain electron diffraction (which I was observing quite well) since there was only one electron (at a time) to cause an interference pattern. The only explanation was that the electron was interfering with its own "propablility wave" which was being scattered by the regular array of atoms in the crystalline sample. Ever since then I have always tried to explain things from a individual photon point a view. Sometimes its difficult though. Signing off for now.
There's no need to describe microwaves quantum mechanically. All of their relevant properties can be gotten straight from Maxwell's equations.
  • · Replies 16 ·
