Calculating Potential Difference for Moving Wire in Earth's Magnetic Field
  • Context: Undergrad
  • Thread starter Thread starter justagirl
The discussion centers on calculating the potential difference across a wire moving through the Earth's magnetic field, specifically when the wire moves north at 10 m/s while the magnetic field is directed east-west. The relevant equation for this scenario is V = Blv, where B represents the magnetic field strength, l is the length of the wire, and v is the velocity of the wire. The right-hand rule is essential for determining the direction of the induced potential difference, with the positive end of the wire being influenced by the motion of positive charges within it. However, the problem lacks specific values for the magnetic field strength, which is crucial for calculating the potential difference accurately.
  • Understanding of motional electromotive force (emf)
  • Familiarity with the equation V = Blv
  • Knowledge of the right-hand rule for magnetic forces
  • Basic concepts of magnetic fields and their directionality
  • Research the application of the right-hand rule in electromagnetic contexts
  • Learn how to calculate potential difference using V = Blv with specific values
  • Investigate typical values of Earth's magnetic field strength in different regions
  • Explore the implications of moving conductors in magnetic fields in practical scenarios
Physics students, educators, and professionals in electromagnetism, particularly those studying the effects of magnetic fields on moving conductors.
justagirl
Hi, I was wondering if you can help me with the following question. I am totally stuck. I'm not sure I even understand the question. Any help or hint would be greatly appreciated!
This is the problem:
Over a region where the vertical component of the Earth's magnetic field is held in an east-west direction and moved horizontally to the north with a speed of 10m/s. Calculate the potential difference between the ends of the wire, and determine which end is positive.
End Problem.
I copied the above question verbatim, and I'm still trying to figure out what it means as it is worded strangely. I assume they're saying that the Earth's magnetic field is directed east-west and the wire is moving north at 10 m/s, perpendicular to the field.
I think this has something to do with motional emf, and the equation V = Blv plays some role. However, B and l are not given so I don't know. And the right hand rule probably has something to do with figuring out which end is positive.
That's all I can deduce. What do you think? Thank you so much for your time.
Think about a single positive charge in the wire. Since the wire is moving, you can attribute its velocity to the charges in it. So this positive charge has a velocity, and it's inside a magnetic field. You should know that in this situation a magnetic force acts on the charge [itex]F_m = q\vec v \times \vec B = qvB\sin \alpha[/itex]. But we don't care about the strength of the force here, we are more concerned with its direction. This page describes an easy method to find the direction of the force:
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/MagneticField/RightHandRule.html
So if know the direction of the magnetic force, you know where the positive charge "goes" as the wire moves through the magnetic field. Similarly, the negative charges will go to the other end of the wire since the force on them is on the opposite direction.
I probably explained things you had already known, but I'm not sure on what level you are so I explained them anyway. The potential difference cannot be calculated without further data.
It is my opinion that some words are missing from this question. I believe it is supposed to say:
Over a region where the vertical component of the Earth's magnetic field is ...{some specific amount in teslas} and a wire is... held in an east-west direction and moved horizontally to the north with a speed of 10m/s. Calculate the potential difference between the ends of the wire, and determine which end is positive.
As given, there is no solution to the problem since no value for the magnetic field is provided. You could use 5 x 10^-5 T, since that is the approximate value for most of the US.
  • · Replies 17 ·
  • · Replies 20 ·
