Calculate Distance Between Maxima of 500 nm Wavelength Light
The calculation of the distance between maxima for light with a wavelength of 500 nm, using two narrow slits spaced 0.10 mm apart and a viewing screen 1.20 m away, results in a distance of 6.0 x 10-3 m between each maximum. The fourth maximum is located 2.4 x 10-2 m from the central maximum. The formula used for this calculation is delta x = (lambda x L) / d, where lambda is the wavelength, L is the distance to the screen, and d is the slit separation.
  • Understanding of wave interference principles
  • Familiarity with the formula for calculating maxima in double-slit experiments
  • Knowledge of units of measurement in physics (meters, nanometers)
  • Basic algebra for manipulating equations
  • Study the principles of wave interference in more depth
  • Learn about the effects of varying slit separation on interference patterns
  • Explore the application of the double-slit experiment in quantum mechanics
  • Investigate the impact of wavelength changes on the distance between maxima
Students in physics, educators teaching wave optics, and anyone interested in understanding light behavior in interference experiments.
Mitchtwitchita
a) A light with a wavelength of 500 nm illuminates two narrow slits that are 0.10 mm apart. If the viewing screen is 1.20 m from the slits calculate the distance between each maximum.
b)how far would the fourth maximum be from the central maximum?
a) Given: lambda = 500 x 10e-9 m
d= 0.1 x 10e-3 m
L= 1.2 m
delta x = lambda x L/d
=(500 x 10e-9 m) (1.2 m)/(0.1 x 10 e-3 m)
=0.0006 m
=6.0 x 10 e-3
Therefore, the distance between each maximum is 6.0 x 10 e-3 m
b) Since the distance between each maximum is 6.0 x 10 e-3 m the fourth maximum would be 4 x (6.0 x 10 e-3 m)
Therefore, 4 x (6.0 x 10 e-3 m) = 2.4 x 10 e-2
Therefore, the fourth maximum would be 2.4 x 10 e-2 m away from the central maximum.
Does this look like I'm doing this question right to anybody?
Yes, you've got it right.
11K
