Von neumann stability analysis
The discussion focuses on the Von Neumann stability analysis applied to the 1D wave equation represented by a hyperbolic partial differential equation (PDE). The central difference approximation is utilized for the second derivatives with respect to time (T) and space (X). The stability condition derived indicates that the scheme is stable if the ratio \( \frac{c dT}{dX} = \lambda \leq 1 \). The analysis reveals that two distinct sigma factors, \( \sigma_1 \) and \( \sigma_2 \), must be considered, leading to constraints on \( \lambda^2 \) based on the cosine function, ultimately ensuring that the roots of the quadratic equation derived from the difference equation remain less than or equal to one.
  • Understanding of hyperbolic partial differential equations (PDEs)
  • Familiarity with central difference approximations
  • Knowledge of stability analysis techniques, specifically Von Neumann analysis
  • Proficiency in solving quadratic equations and interpreting their implications
  • Study the derivation and implications of the Von Neumann stability condition in numerical methods
  • Learn about the application of finite difference methods to hyperbolic PDEs
  • Explore the relationship between wave speed, time step, and spatial step in numerical simulations
  • Investigate the impact of boundary conditions on stability in numerical solutions of PDEs
Mathematicians, numerical analysts, and engineers involved in computational fluid dynamics, finite difference methods, and stability analysis of numerical schemes for PDEs.
deadringer
We have a hyperbolic pde (in fact the 1d wave equation) with indep vars X, T
We use the central difference approximations for the second derivatives wrt X, T to get
[phi(Xn, Tj+1) -2phi(Xn, Tj) + phi(Xn, Tj+1)]/(dT^2) = [c^2][phi(Xn-1, Tj) -2phi(Xn, Tj) + phi(Xn=1, Tj)]/(dX^2)
where dX and dT are the changes in the independent variables between steps, c is the speed of the wave.
We are supposed to show that the scheme is stable only if cdT/dX = lambda<=1
We have to apply Von Neumann stability analysis. This usually means assuming a solution of the form phi = A(T)*exp(ikX)
Xn = ndX
therefore phi(Xn, Tj) = Aj*exp(ikndX)
The stability condition is that sigma = Aj+1/Aj and we want the modulus of sigma is less than or equal to one.
The first problem I have is that the above PDE finite difference equation has phi's with three different times in it; j-1,j,j+1. Therefore I tried using two differenct sigma factors sigma1 = Aj/Aj-1 and sigma2 = Aj+1/Aj
I do not think that you can assume that these are the same. I think that for stability you need the modulus of both sigmas is less than or equal to one.
the original finite difference equation gives us
sigma1 = 1/[2(lambda^2)cos(kdX) +2(1-(lambda^2)) - sigma2)
I set the modulus of this is less than or equal to one (call this stage A), giving two more equations:
-2(lambda^2)cos(kdX) - 2 + 2(lambda^2) + sigma2 <=1
this must be true for the largest values of the LHS (i.e when sigma2 = 1) , giving us Lambda^2 <= 1/(1-cos(kdX))
The RHS is largest when cos = 0, and also note that dX, dT, c are all positive by def'n, giving us the required condition. The only problem is we also get another equation from stage A:
2(lambda^2)cos(KdX) + 2 - 2(lambda^2) - sigma2 >=1
This must be true for the smallest values of the LHS i.e when sigma2 = 1
This implies that (lambda^2)(cos(kdX) - 1)>=0
We know that lambda^2>=0 which means that the other bracketed term must be greater than or equal to one. This is only satisfied for cos = 0
This extra condition was not mentioned in the question and doesn't look right. I'm not sure where I've gone wrong.
From what I remember about this stuff, you plug the assumed solution [tex]\phi(x,t)=A(t)e^{ikx}[/tex] into the difference equation, and then use the fact that [tex]x[n+m]-x[n]=m \Delta x[/tex] to obtain an ordinary difference equation in t_j which can be solved exactly.
So in this case you would obtain
[tex]e^{ikx[n]}(A[j+1]-2A[j]+A[j-1]) = \frac{c^2 \Delta t^2}{\Delta x^2} A[j] (e^{ikx[n-1]} - 2e^{ikx[n]} + e^{ikx[n+1]})[/tex]
which you can rearrange as
[tex]A[j+1] + (\alpha-2)A[j] + A[j-1] = 0[/tex]
where
[tex]\alpha = \frac{c^2 \Delta t^2}{\Delta x^2}(2cos(k\Delta x)-2)[/tex]
( or something similar to that).
Difference equations have solutions of the form [tex]A[j] = z^j[/tex], so plug that solution into the final difference equation above and you end up with a quadratic equation in z. Note that the solutions z depend on alpha. Then, since the original solution is now [tex]\phi = z^j e^{ikx}[/tex], you need z<=1 to prevent the solution from blowing up as j grows, so you need to pick alpha to give you z roots which are less than one.
So if you solve the quadratic equation for z as a function of alpha, you will get a constraint on alpha, and then using the definition of alpha, that should give you a constraint on c^2dt^2/dx^2 which is the one you're after.
  • · Replies 24 ·
  • · Replies 235 ·
19K
