How do I construct a cubic inequality with specific solution sets?
  • Context: High School
  • Thread starter Thread starter iluvrotinsaag
The discussion revolves around constructing a cubic inequality that has specific solution sets, particularly focusing on the intervals -2 < x < 0 and x > 3. Participants explore the formulation of the inequality and the implications of different signs in the inequality.
  • One participant expresses uncertainty about the correct sign to use in the inequality and seeks clarification on the concept.
  • Another participant questions the formulation of the inequality and the meaning of the specified intervals.
  • A participant suggests that the cubic inequality is defined by the intervals -2 < x < 0 and x > 3.
  • One participant admits to confusion regarding the term "cubic inequality" and refrains from contributing further.
  • A suggestion is made to verify the direction of the inequality by substituting values into the expression and checking the results.
  • Another participant proposes constructing a polynomial equation based on the given solution sets and discusses the behavior of the polynomial to determine the inequality.
  • A distinction is made between constructing an inequality for the specified solution set versus its complement, illustrating the process with examples.
Participants do not reach a consensus on the correct formulation of the inequality, and multiple competing views remain regarding the interpretation and construction of the cubic inequality.
There are limitations in the discussion regarding the assumptions made about the intervals and the behavior of the polynomial, as well as the clarity of the term "cubic inequality." Some mathematical steps remain unresolved.
iluvrotinsaag
Math problems!
I understand how to solve this inequality, but i do not know what sign to put (greater than or less than) in my answer. I would really appreciate it if someone could explain this concept to me. THanks
Write a cubic inequality that has this solution:
-2<X<0, x>3
(X)(X+2)(X-3)
(X^2 +2X) (X-3)
X^3 - X^2 - 6X (< or >) 0
Mathematics news on Phys.org
Whoa, hold on. What's the inequality?
x>3 into the expression x^3 - x^2 - 6x?
What's the -2<x<0?
cookiemonster
the cubic inequality is:
-2<X<0 and x>3
I've never heard of a cubic inequality before (other than a cubic polynomial used in an inequality), so I'll just butt out of this before I make a fool of myself again.
cookiemonster
you can always check if you have the inequality the right way round you do not need a method for checking if its "<" or ">" other than subbing in points
for example
when x=4, the statement x> 3 is true
and the statement 4^3-4^2-6*4=24 > 0 is true so the answer better be
x^3 - x^2 - 6x> 0
not x^3 - x^2 - 6x <0.
There is no mystery here just sketch the curve y=x^3 - x^2 - 6x
and notice there are two regions above the x-axis, one region has the property that all x values are between -2 and 0 (-2< x< 0) and the other region is x>3
Apparently the problem is not to "solve an inequality" but to construct an inequality having all numbers between -2 and 0 and all numbers above 3 as solutions.
Start by constructing an equation:
(x-(-2))(x-0)(x-3)= (x+2)(x)(x-3)= x3+ 5x2+ 6x= 0 is 0 at exactly -2, 0, and 3. Since a polynomial is continuous, it can change from positive to negative and vice-versa only where it is 0.
Now check what happens in between: at x= 1, for example,
13+ 5(12)+ 6(1)= 1+ 5+ 6= 11> 0. Therefore, the inequality x3+ 5x2+ 6x> 0 has x<-2 and 0< x< 3 as solution set.
IF the problem had asked for the complement set: -2< x< 0, x> 3, then we would have tried x= -1, say, and found that
(-1)3+ 5(-1)2+ 6(-1)= -1+5-6= -2< 0.
The inequality x3+ 5x2+ 6x< 0 has that solution set.
