Solving Chemistry Questions: Mercury (II) Sulfide HgS
  • Thread starter Thread starter heartsxxskulls
    Chemistry
The discussion focuses on the properties of Mercury (II) sulfide (HgS), specifically its two forms: red vermillion and black. The red form has a larger band gap due to its color being associated with the absorption of complementary colors. In weak field octahedral complexes, the d-d transitions are more likely to result in a blue color, as the color observed is the complementary color of the absorbed frequency. This is supported by crystal field theory, which outlines the relationship between absorbed wavelengths and observed colors.
  • Understanding of band gap transitions in materials
  • Familiarity with crystal field theory
  • Knowledge of d-d transitions in coordination complexes
  • Basic concepts of color theory and complementary colors
  • Research the properties of different forms of Mercury (II) sulfide (HgS)
  • Study the principles of crystal field theory in depth
  • Explore the implications of band gap transitions on color perception
  • Investigate the effects of weak field versus strong field ligands on d-d transitions
Chemistry students, educators, and researchers interested in the optical properties of transition metal complexes and the application of crystal field theory in understanding color phenomena.
heartsxxskulls
Mercury (II) sulfide. HgS, occurs in two forms. One is red pigment known as vermillion; the other is black. In both, the color is due to band gap transitions (BGT). Which form has the larger band gap?
In weak field octahedral complexes, DELTA is relatively small. Are the d-d transitions in these complexes more likely to make the complex red or blue?
for my first question I believe the answer is Red.
for my second question I believe the answer is blue.
Sounds like good logic. Remember that the color you see is the complimentary color of the absorbed frequency.
From Wiki: (crystal field theory)
λ absorbed versus colour observed
400nm Violet absorbed, Green-yellow observed (λ 560nm)
450nm Blue absorbed, Yellow observed (λ 600nm)
490nm Blue-green absorbed, Red observed (λ 620nm)
570nm Yellow-green absorbed, Violet observed (λ 410nm)
580nm Yellow absorbed, Dark blue observed (λ 430nm)
600nm Orange absorbed, Blue observed (λ 450nm)
650nm Red absorbed, Green observed (λ 520nm)
11K
9K
