Could Every Particle Actually be a Point Singularity?
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
The discussion centers on the hypothesis that every particle may be a point singularity, particularly in the context of string theory. String theory suggests that strings can transform into small black holes, implying shared properties with singularities. The conversation references electromagnetic theory, which treats particles as singularities mathematically, while also exploring the implications of inverse square laws in physics, such as Newton's law of gravitation and Coulomb's law. The inability of experimental data to consistently support theoretical models highlights the complexities of understanding particle properties, particularly the magnetic dipole moments of particles like electrons and neutrinos.
  • Understanding of string theory and its implications on particle physics.
  • Familiarity with electromagnetic theory and mathematical singularities.
  • Knowledge of inverse square laws in physics, including Newton's law of gravitation.
  • Basic concepts of magnetic dipole moments and their significance in particle physics.
  • Research the principles of string theory and its relationship to black holes.
  • Explore the mathematical foundations of electromagnetic theory and singularities.
  • Study the implications of inverse square laws in various physical contexts.
  • Investigate the properties of magnetic dipole moments in elementary particles.
Physicists, theoretical researchers, and students interested in advanced particle physics and the implications of singularities in modern theories.
is it too much to think that every particle is actaully a point singularity?
i think that if string theory is correct than this assumption could be correct because string theory argues that strings can become a small black hole and vise versa so therefore i assume that they share the same propeties therefore singularity is one of them.
i found in google that in electromagnetic theory particles are assumed to be singularities but i assume they refer to mathematical singularity nd not physical.
here's what i found (you should know that i haven't read thoroughly):
http://www.google.co.il/search?q=cache:5EZNChW6HBAJ:arxiv.org/pdf/physics/9706011+a+particle+is+singularity&hl=iw&ie=UTF-8
loop quantum gravity,
If we look at three inverse square laws of physics; Newton's universal law of gravitation, Coulomb's law of electrostatic and Ampere's law of magnetostatic, as the distance approaches zero into a point, the force becomes infinite.
Yet to compute the gravitational force of a sphere of uniform mass density distribution, the force originates from a singularity as if all the masses is at a point.
Both mathematician and physicist do want to compute accurately but the experimental data refuse to cooperate.
No uniform mass density can be found in nature except the vacuum (mass is zero?). The electron is a point particle. Together with its antiparticle, the positron, their mass is equal. Yet they possesses a magnetic dipole moment, which indicates internal charge distribution. So they can't really be a point particle in the physical sense. Experiment just cannot detect this extended property of point particles. Even the neutrinos do possesses a very small amount of magnetic dipole moment.
Science don't yet have the answer why experiments can detect the magnetic moment but not the extension of the point.
No uniform frame of velocity can be found except light's frame (speed is constant in vacuum).
  • · Replies 60 ·
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 167 ·
