Proving Integral Identity: \int_0^a f(x)dx = \int_0^{\frac{a}{2}}[f(x)+f(a-x)]dx
  • Thread starter Thread starter John O' Meara
    Proof
The discussion revolves around proving an integral identity involving a function \( f(x) \) and exploring its implications for a specific integral involving \( \sin^6 x \). The subject area is calculus, specifically focusing on integral properties and transformations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various methods to manipulate the integral limits and apply change of variables to prove the identity. There are attempts to clarify the implications of reversing integral bounds and the properties of odd functions.
The discussion is ongoing, with participants providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the manipulation of integral bounds and the use of change of variables, but no consensus has been reached on the complete proof.
Participants are navigating through the complexities of integral transformations and theorems, with some expressing uncertainty about the correctness of their approaches. There is a focus on ensuring that the mathematical manipulations adhere to proper conventions.
John O' Meara
Prove that [tex]\int_0^a f(x)dx = \int_0^{\frac{a}{2}}[f(x) + f(a-x)]dx \\[/tex]
Hence prove that [tex]\int_0^{\pi} x sin^6x dx = \pi \int_0^{\frac{\pi}{2}} sin^6x dx \\[/tex] and evaluate this integral using the following reduction formula [tex]I_{m,n}= \frac{n-1}{m+n}I_{m,n-2} \\[/tex]
My effort:
[tex]\int_0^a f(x)dx = \int_0^{\frac{a}{2}}f(x)dx + \int_{\frac{a}{2}} f(a-x)dx \\[/tex]. Now
[tex]\int_{\frac{a}{2}}^a f(x)dx = \int_{\frac{a}{2}}^a f(a-x)dx \\[/tex] ... by a theorem. Therefore [tex]\int_0^a f(x)dx = \int_0^{\frac{a}{2}} f(x)dx + \int_{\frac{a}{2}}^a f(a-x)dx \\[/tex]. I need help to change the integral's limits to 0 and a/2 on the second integral on the right, thanks very much.
[tex]\int_{0}^{a}f(x)dx[/tex]
change variable u=a-x then we have du=-dx
[tex]-\int_{a}^{0}f(u)du=-\int_{0}^{a}f(a-x)dx[/tex]
so now you have: [tex]\int_{0}^{a}f(x)dx=\int_{0}^{a}[f(x)-f(a-x)]/2dx[/tex]
another change u=x-(a/2), which gives you:
[tex] \int_{-a/2}^{a/2}f(u+a/2)-f(a/2-u)]/2du[/tex]
this function in the integrand is an odd function, which means that this equals 2 times the integral but from 0 to a/2.
if I am mistaken, sorry for misleading.
You are mistaken :( [tex]\int^a_0 f(x) dx = \int^a_0 f(a-x) dx[/tex]
On your 2nd line of latex, Reversing the bounds as you did makes the integrals value negative, canceling the other negative.
Jean - To finish it off, u=x - (a/2) for the last integral.
well it should be [tex]-\int_{a}^{0}f(a-u)du=\int_{0}^{a}f(a-u)du[/tex]
so yes, you are right, thanks for the correction.
  • · Replies 105 ·
13K
