What Are the Possible Changes in the Fine Structure Constant in the Past?
The discussion revolves around the potential changes in the Fine Structure constant over time and the implications of such changes on fundamental physical constants. Participants explore theoretical frameworks, experimental challenges, and the significance of dimensionless versus dimensionful constants in this context.
  • Some participants inquire about which fundamental constants (C, e, E0, h) could have varied in the past to affect the Fine Structure constant.
  • One participant shares insights from their thesis, suggesting that variations in the speed of light could be theoretically equivalent to variations in electron charge, highlighting the complexity of these relationships.
  • Another participant notes the difficulty in detecting changes in dimensionless constants, as any variation complicates measurement standards.
  • References to John Barrow's work on varying constants are provided, indicating ongoing research into the implications of changes in the speed of light and the Fine Structure constant.
  • Some participants express uncertainty about the specifics of how these theoretical frameworks operate and the implications of varying constants.
Participants do not reach a consensus on the specifics of which constants may have changed or the implications of such changes. Multiple competing views and uncertainties remain regarding the nature of these variations and their detectability.
Limitations include the ambiguity in defining and measuring dimensionful constants, as well as the unresolved nature of the theoretical frameworks discussed. The discussion also reflects a lack of clarity on the practical implications of varying constants in cosmology.
talksabcd
Scientists are doing experiments to find any change in the Fine Structure constant in the past.
It is dependent on the following constants.
C (Velocity of Light)
e (Charge of the electron)
E0 (Permittivity of free space)
h (plancks constant)
Could you pls let me know which of the above constants would have been different in the past which inturn would have made fine structure constant different ?
Astronomy news on Phys.org
I worked on varying alpha for my honours thesis some years ago. I had the same question as you at the time. As it turns out the answer is somewhat subtle. It turns out that it you construct a theory in which the speed of light varies then it can be shown to be equivalent to a theory in which say the electron charge varies but c stays constant. It sounds odd and I must admit I do not fully understand the details of this, but it has been demonstrated that this is the case (theoretically of course!).
The moral of the story is that it turns out the only thing that matters is changes in dimensionless constants, such as the fine structure constant. A change in a dimensionfull constant (c,e etc) can always be reconstructed in ambiguous ways, since units are defined by humans. But changes in dimensionless ratios indicates a real variation in physics.
Sorry I can't be any more specific as to the whys, it was always a question I though about when I was working on this and never fully grasped. I will see if I can find some references for you.
It's very difficult to devise a test where you can detect a change in a dimensionless constant. Any such variation messes with whatever yardstick you use to measure it.
John Barrow seems to have done plenty of work in the field of varying constants. I've read quite a lot of work investigating a possible change in the speed of light (though it must be pointed out that if there is a change in alpha it now looks to be extremely small).
Here are some interesting papers on varying constants:
http://arxiv.org/PS_cache/astro-ph/pdf/0511/0511440v1.pdf (Barrow, J.D.)
http://arxiv.org/PS_cache/gr-qc/pdf/0209/0209080v1.pdf (Mota, David.F.,Barrow, J.D)
And those specific to varying alpha:
http://arxiv.org/PS_cache/astro-ph/pdf/0309/0309273v2.pdf (Barrow,J.D)
http://arxiv.org/PS_cache/astro-ph/pdf/0202/0202374v1.pdf (Maguiejo,J. Barrow, J.D, Sandvik, H.)
The cosmological implications of a varying alpha are also worth looking at.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 163 ·
29K
  • · Replies 18 ·
