A different kind of solar power
The discussion revolves around alternative methods of harnessing solar energy, specifically focusing on using sunlight as a heat source rather than directly converting it to electricity. Participants explore the potential for using large lenses to concentrate sunlight and the theoretical efficiencies that could be achieved through this method.
  • One participant suggests that instead of using solar cells, sunlight could be focused using large lenses to heat a liquid, potentially achieving efficiencies greater than 25%.
  • Another participant mentions existing solar heating systems that use black pipes to heat water efficiently, indicating that the proposed method may not be necessary.
  • A participant notes that direct solar heating is already in use in Europe, particularly in Germany, and highlights the need for additional heating methods alongside solar heating.
  • Concerns are raised about the practicality of using large lenses, including the need for orientation and the challenges of tracking solar concentrators.
  • References are made to technologies such as Stirling engines and thermionic solar energy, which utilize concentrated sunlight, suggesting that these methods may face their own challenges.
  • Fresnel lenses are mentioned as a potentially cheaper alternative for concentrating sunlight.
Participants express a range of views on the feasibility and efficiency of using concentrated solar heating. There is no consensus on the practicality of the proposed method, as some participants highlight existing technologies and methods while others question the viability of large lens systems.
Participants discuss various assumptions regarding efficiency, practicality, and existing technologies without resolving the uncertainties surrounding the proposed methods. Limitations related to the tracking of solar concentrators and the need for additional heating sources are noted.
Just some guy
Well this is fairly simple so I guess there's a flaw in my 'plan' somewhere :p, but hey here goes.
Current solar cells are only about 25% efficient, however instead of using sunlight to directly generate electrical current why not use it as a heat source?
Of course sunlight is normally low grade heat, but why can't giant lens systems be used to focus the sunlight on a smaller area? Lenses are just ground class and they could be pretty crude, and the only energy losses would be from sunlight reflecting off the surface of whatever they're heating. If you heated a fairly volatile liquid with a low reflectivity (um...water with black dye? :p ok maybe something more refined than that) then you would only need to heat up the water to just a bit over boiling point to have a theoretical maximum efficiency of >25% (if your cold reservoir was the sea or something cold like that), and considering how tightly you could focus the sunlight the efficiency could be bumped to well over that of a conventional solar cell, and all that using ground glass and a simple heat engine.
So where's the flaw? why hasn't it been done? would the yeilds be too low to bother with the whole thing? Is making giant lenses harder than I think?
Cheers,
Zac.
Im not sure about the efficiency of these but it sounds very similar to what you are describing.
http://www.renewableenergyaccess.com/rea/news/story?id=44696
You can, of course, also use solar to heat water for heat and hot water, with very high efficiencies. And you don't need black water - just black pipes.
Direct solar heating is currently used in Europe, mostly in Germany. Of course you can't use only solar heating, you need to complete with another kind of heating.
Lenses are big and must be oriented. What you do is use parabolic reflectors in the back of each pipe. Pipe panels are fixed and inclined to be perpendicular to the Sun.
Don't forget to put antifreeze in the water (some have).
Sunlight can be concentrated and used with a Stirling engine.
check:
http://en.wikipedia.org/wiki/Stirling_engine
There is also something called, I think thermionicsolar. It uses a semiconductor with a low band gap and gets energy from a heat source.
There are some problems with concentrators though mainly due to tracking. Also, with the use of multijunction cells, some people (I think spectrolab and boeing if I remember correctly) have achieved 39% efficiency.
Check out Fresnel lenses for a cheaper method to concentrating light.
  • · Replies 30 ·
  • · Replies 21 ·
