Solving for ln(-e), (-1)^i, and (2i)^1+i in Rectangular Form
  • Thread starter Thread starter ilikephysics
The discussion focuses on calculating the values of ln(-e), (-1)^i, and (2i)^(1+i) in rectangular form using the principal value of the logarithm. The calculations confirm that ln(-e) equals 1 + iπ, (-1)^i simplifies to cos(π/ln(e)) + i*sin(π/ln(e)), and (2i)^(1+i) results in cos(ln(2)*ln(2)/ln(e)) + i*sin(ln(2)*ln(2)/ln(e)). Each expression is derived using properties of logarithms and Euler's formula, emphasizing the importance of converting to polar form for accurate computation.
  • Understanding of complex numbers and their representations
  • Familiarity with logarithmic properties and the principal value of logarithm
  • Knowledge of Euler's formula and De Moivre's theorem
  • Ability to convert between rectangular and polar forms of complex numbers
  • Study the properties of logarithms in complex analysis
  • Learn about polar coordinates and their application in complex number calculations
  • Explore Euler's formula in greater depth, particularly its applications in complex exponentiation
  • Investigate advanced topics in complex analysis, such as analytic continuation and branch cuts
Students and professionals in mathematics, particularly those focusing on complex analysis, as well as anyone interested in advanced logarithmic functions and their applications in engineering and physics.
ilikephysics
Find the value of ln(-e), (-1)^i, and (2i)^1+i in rectangular x+iy form, using the principal value of the logarithm.
This is what I'm doing for each one:
ln(-e)= e^ln(-e)
(-1)^i= e^(i)(ln(-1))
(2i)^1+i= e^(1+i)ln(2i)
If this is right, where do I go from here?
Well, each statement is TRUE but do they help at all?
One reason the problem specifically says "in rectangular form" is that you will want to convert to "polar form" to do the calculations- then convert back.
If you write a complex number z= x+iy in "polar form" as
r eiθ, then ln(z)= ln(r)+ iθ Notice that in the first for, r eiθ, adding or subracting π to θ will not change z but will change ln(z). The point of "principal value of the logarithm" is to specify θ: it must be between 0 and 2π.
In particular, -e= e ei(π). That is, r= e and θ= iπ. ln(-e)= ln(e)+iπ= 1+ iπ
For (-1)i, use the fact that (eiθ)i= e(i*i)θ= e-θ. -1= eiπ so -1i= e-π.
To solve for ln(-e), we can use the properties of logarithms to rewrite it as ln(e^-1) and then use the fact that ln(e) = 1 to get ln(-e) = -1. This means that the rectangular form of ln(-e) is -1 + 0i.
For (-1)^i, we can use the fact that i is equal to ln(-1)/ln(e) and rewrite it as e^(ln(-1)/ln(e)). Using the properties of logarithms again, we can rewrite this as e^(ln(-1))^(1/ln(e)). Since ln(-1) is equal to i*pi, we have (-1)^i = e^(i*pi)^(1/ln(e)). We can then use Euler's formula, e^(ix) = cos(x) + i*sin(x), to get (-1)^i = cos(pi/ln(e)) + i*sin(pi/ln(e)). Therefore, the rectangular form of (-1)^i is cos(pi/ln(e)) + i*sin(pi/ln(e)).
Finally, for (2i)^1+i, we can use the properties of logarithms once again to rewrite it as (2i)^ln(2i)^(1/ln(e)). Using Euler's formula, we can rewrite this as (2i)^(i*ln(2))^(1/ln(e)). Simplifying, we get (2i)^i^(ln(2)/ln(e)). Again, using Euler's formula, we can rewrite this as (cos(ln(2)) + i*sin(ln(2)))^(ln(2)/ln(e)). Finally, using De Moivre's theorem, we can simplify this to (cos(ln(2)*ln(2)/ln(e)) + i*sin(ln(2)*ln(2)/ln(e))). Therefore, the rectangular form of (2i)^1+i is cos(ln(2)*ln(2)/ln(e)) + i*sin(ln(2)*ln(2)/ln(e)).
  • · Replies 116 ·
