Parallel/series, calculate current drawn
  • Thread starter Thread starter mikefitz
    Current
The problem involves calculating the current drawn in a circuit with multiple resistors arranged in both series and parallel configurations. The original poster provides specific resistor values and attempts to apply Ohm's law and formulas for series and parallel resistances.
  • Participants discuss the arrangement of resistors, suggesting that certain resistors should be considered in parallel or series to simplify the calculations. There are questions about the original poster's calculations and where errors may have occurred.
The discussion is ongoing, with participants providing insights into the configuration of the resistors and suggesting corrections to the original poster's approach. There is no explicit consensus yet, as different interpretations of the circuit configuration are being explored.
Some participants note potential errors in the original poster's resistor values and calculations, indicating a need for clarification on the circuit setup. The original poster's values and the arrangement of resistors are under scrutiny.
mikefitz
http://img267.imageshack.us/img267/8159/untitled3ct1.gif
Find the current drawn.
V=IR
R1+R2+Rn
1/ (1/R1)+(1/R2)+(1/R3)+(1/R4)
R1=20,000ohms
R2=70,000ohms
R3=96,7000ohms
R4=40,000ohms
1/ (1/R1)+(1/R2)+(1/R3)+(1/R4) = 10037.44
10=I(10037.44)
I=.000996A
Where did I go wrong?
Think of the two 30Kohm resistors as being in parallel. Also, think of the 40 and 66.7 kohm resistors as being in parallel. Now, you have simplified that whole middle section into two resistors in series. you can go from here.
Simple error, the 30K resistors are in parallel, as are the 40K and 66.7. These in turn are in series and that resultant in parallel with the other two branches.
r1=20,000
r2=15,000
r3=25,004.7
r4=40,000
r2&r3 in parallel= 9,375.5
20,000+9,375.7+40,000=69,375.5
10=I(69,375.7)
I=.000144A ??
Almost R2 and R3 are in series.
