Why does the precipitate dissolve, reappear, and then dissolve again?
  • Thread starter Thread starter billabonger77
    Dissolve
The discussion focuses on the behavior of silver chloride (AgCl) precipitate during a series of chemical reactions involving silver nitrate (AgNO3), hydrochloric acid (HCl), ammonium hydroxide (NH4OH), and sodium thiosulfate (Na2S2O3). Initially, AgCl precipitates when AgNO3 reacts with HCl. The addition of NH4OH causes the AgCl to dissolve, forming soluble silver hydroxide (AgOH). Upon reintroducing HCl, AgCl precipitates again, and finally, the addition of sodium thiosulfate leads to the dissolution of AgCl, forming a soluble complex. This cycle of precipitation and dissolution is a result of the solubility properties of the involved compounds.
  • Understanding of chemical reactions and stoichiometry
  • Knowledge of solubility rules for ionic compounds
  • Familiarity with the properties of silver compounds
  • Basic grasp of acid-base reactions and complexation
  • Study the solubility rules for common ionic compounds
  • Learn about complexation reactions involving silver ions
  • Investigate the role of pH in precipitation reactions
  • Explore the applications of silver compounds in analytical chemistry
Chemistry students, laboratory technicians, and educators looking to deepen their understanding of precipitation reactions and solubility principles in inorganic chemistry.
billabonger77
why does the precipitate dissolve, reappear, and then dissolve again??
i have a chem lab due tuesday and was wondering if anyone may please help me on it!
the problem:
Mix silver nitrate solution and hydrochloric acid solution. Product is a precipitate
2. Add ammonoum hydroxide solution drop by drop. precipitate dissolves.
3. Add hcl again. precipiate forms
4. add sodium thiosulfate..precipitate dissolves.
1. AgNO3 + HCl -> HNO3 + AgCl
HNO3 is soluble, but AgCl isn't (see solubility rules), so it precipitates.
2. AgCl + NH4OH -> AgOH + NH4Cl
It dissolves? Really? :/
3. AgOH + HCl -> AgCl + H2O
AgCl is insoluble again, so it precipitates again.
4. 2AgCl + Na2S2O3 -> Ag2S2O3 + 2NaCl
Uhhh...
Well, at least you have the equations :P.
hey how does the equations get affected when i use
1> 5mL of 0.1 M of silver nitrate solution mixed with 5mL of 0.1 M HCl.
2. then added 6 M ammoniumn hydroxide solution, drop by drop
3. then added 10 mL of 0.1 M HCl solution
4. then added 5mL of .15 M sodium thiosulfate
