Thread Closed
What does fatty acid synthesis imply?
Share Thread
May7-07, 11:46 AM   #1
Sorry, I'm not much of a biology expert, but I was looking into the interactions between b5 and omega 3 fatty acids. I wanted some help clarifying this.
Pantothenic acid is involved in a number of biological reactions, including the production of energy, the catabolism of fatty acids and amino acids, the synthesis of fatty acids, phospholipids, sphingolipids, cholesterol and steroid hormones, and the synthesis of heme and the neurotransmitter acetylcholine.
http://www.pdrhealth.com/drug_info/n...pan_0196.shtml
Does that imply that it breaks down fatty acids and uses them as energy? Or does it help in the break down and uptake, and usage of fatty acids?
Basically, will this hurt omega fatty acid intake by burning off fats, or actually make better use of them by using them for their essential purpose better?
Thank you for your time, I respect the knowledge this community has to offer!
PhysOrg.com biology news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
May7-07, 01:31 PM   #2
I think you are making this sound harder than it is. Pantothenic acid is just a molecule that is used in the synthesis of those molecules listed. You need this thing in order to make other things like those hormones, neurotransmitters. It's just a building block. It does not make and break anything on its own. lets see, it is part of fatty acid breaking down pathway, I guess it means you need to make CoA from it, then acetyl CoA from CoA. Anyway, it on its own is not going to do anything. It's not goint to make you lose weight or anything. These articles are always so general, gives people headaches, arent you annoyed by it too?
ask more or private message me if u need more stuff
May7-07, 02:08 PM   #3
Thank you contrio,
I understand what you mean, it makes sense. I was trying to simply over analyze it and started to confuse myself. You are right, it was overly simplified in a sense.
Thread Closed
Similar discussions for: What does fatty acid synthesis imply?
Thread Forum Replies
calculating molecular mass of oxalic acid (diprotic acid) using only given #s? Biology, Chemistry & Other Homework 1
titrating weak acid buffer with strong acid after the base is used up Biology, Chemistry & Other Homework 6
Saturated Fatty Acids Biology, Chemistry & Other Homework 7
Something about fatty acid Biology, Chemistry & Other Homework 1
Three essential fatty acids Biology, Chemistry & Other Homework 6
