How Does a Positively Charged Oil Drop Behave in a Uniform Electric Field?
  • Thread starter Thread starter kbyws37
    Charged Drop Oil
A positively charged oil drop in a uniform electric field experiences an electric force of 8.60 × 10−16 N and an electric field magnitude of 153 V/m. The correct calculation for the charge on the drop, expressed in terms of elementary charge e, is 35e. The user initially attempted to use the formula F = Eq but incorrectly calculated the charge as 5.6 x 10−18 N. The correct approach requires dividing the charge by the elementary charge value of 1.6 x 10−19 C to express it in terms of e.
  • Understanding of electric fields and forces
  • Familiarity with the formula F = Eq
  • Knowledge of elementary charge (e = 1.6 x 10−19 C)
  • Basic algebra for solving equations
  • Review the concept of electric fields and forces in physics
  • Practice using the formula F = Eq with different values
  • Learn about the significance of elementary charge in electrostatics
  • Explore the relationship between charge, force, and electric field strength
Students studying physics, particularly those focusing on electrostatics, as well as educators looking for examples of charge calculations in electric fields.
kbyws37
A positively charged oil drop is injected into a region of uniform electric field between two oppositely charged, horizontally oriented plates. If the electric force on the drop is found to be 8.60 × 10−16 N and the electric field magnitude is 153 V/m, what is the magnitude of the charge on the drop in terms of the elementary charge e?
The correct answer should be 35e, but I am not getting it.
My attempt:
I tried the equation
F = Eq
8.60 × 10−16 N = (153 V/m)(q)
q = 5.6 x 10-18 N
Then I used
e = q/k
e = 5.6 x 10-18 N / 8.99 x 10^9
which does not give me the right answer
F = Eq
q = 5.6 x 10-18 N
Good :smile:
kbyws37 said:
Then I used
e = q/k
Not so good. I don't know where you got that equation from, but to express your charge in terms of elementary charges, you have to divide through by the value of the elementary charge (1.6x10-19 C).
  • · Replies 52 ·
