How does water repel for a split sec?
  • Context: High School
  • Thread starter Thread starter u83rn00b
    Repel Split Water
The discussion centers on the phenomenon of water seemingly repelling an object upon initial impact, particularly when diving into water. Participants explore the mechanics behind this brief repulsion and subsequent absorption, touching on concepts such as surface tension and the fluid dynamics involved.
  • Exploratory, Technical explanation, Debate/contested
  • One participant expresses fascination with the initial repulsion experienced when diving into water, questioning the mechanics behind it.
  • Another participant suggests that surface tension is a contributing factor to the observed phenomenon.
  • Some participants argue that the inability of water to move out of the way quickly enough is a key factor, indicating that if the impact is forceful enough, the water cannot flow around the diver.
  • A later reply mentions that if surface tension were the sole factor, it could be mitigated by using detergents, implying that other forces are at play.
  • Another participant agrees that surface tension may play a role but emphasizes the incompressibility of water as a significant reason for the initial resistance.
Participants do not reach a consensus on the primary cause of the repulsion, with multiple competing views regarding the roles of surface tension and fluid dynamics remaining present in the discussion.
Some assumptions about the nature of water and its behavior under impact are not fully explored, and the discussion does not resolve the complexities of the interactions involved.
u83rn00b
This has always fasinated me, I am only like a kid so don't hate me!
:confused: When u dive into water, as soon as you hit, for a millionith of a second, the surface of the water kind of repels you. It is enough to (from a headdive) break your neck. But after that slight millionth of a second, the water kind of absorbs u.. How is it this happens? can any1 help mee?? :confused:
Surface tension.
I think it's more a question of whether the water can move out of the way quickly enough. If you hit it hard enough, it can't flow around you. If the issue were surface tension, you could remove the effect with detergents.
Bing! Bing! Congratulation's cesiumfrog, you win a car!
I wouldn't be surprised if surface tension plays some role. But as Cesiumfrog said, it's probably that the water can't flow quickly enough. This is because water, like all liquids, is incompressible, and if it doesn't flow around a solid, it won't give way for that solid by any other means.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 69 ·
18K
16K
