New Reply
Kinematics Question (two objects thrown up)
Share Thread Thread Tools
May8-07, 10:59 AM   #1
I'm sure this is an easy question but I just can't seem to understand wich equations I need to use. A ball is thrown vertically upward with an initial speed of 11m/s. One second later, a stone is thrown veritcally upward with an initial speed of 25 m/s. Find the time it takes the stone to to catch up with the ball.
So right now I have for the ball: a= -9.80 m/s^2 initial V=11m/s initial y=0 t=t2-1 and for the stone a=-9.80m/s^2 initial V=25m/s initial y=0 t=?
So the way I was thinking is that the question is asking at what time the displacements are equal so I thought the equation I am supposed to use is (V^2-iV^2)/2a=(V^2-iV^2)/2a and solve for the V. This doesn't seem to work. Am I on the right track or just totally way off base? Any help or hints would be appreciated. Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May8-07, 11:07 AM   #2
Considering that you have initial velocities, accelerations and a relation between time taken, how about the second equation of motion?
May8-07, 11:20 AM   #3
the movement 2 events equivalent displacement
s1 = u1t1 + (1/2)gt12
s2 = u2t2 + (1/2)gt22
s1 = s2
u1t1 + (1/2)gt12 = u2t2 + (1/2)gt22
but substitute t1 by t2+1
(find t2) time of the second ball moving
May8-07, 11:05 PM   #4
Quote by DAKONG View Post
s1 = s2
Could you tell me why it is t2+1 instead of t1+1? I'm just thinking that because the stone is thrown up one second later. As in ball=t stone=t+1 ? are you saying it's the other way around?
May8-07, 11:26 PM   #5
t2=stone's time
t1=ball's time
Because however long the stone has been flying (t2), the ball has been flying for one second longer (t1=t2+1).
If you prefer, you could also say that no matter how long the ball has been in the air (t1), the stone has been in the air one second less (t2=t1-1)
May9-07, 05:55 PM   #6
Quote by mbrmbrg View Post
t2=stone's time
t1=ball's time
I get a negative value for t if I do this and a positive value the other way.. is my algebra just off? Thanks for the help.
May9-07, 06:09 PM   #7
I would assume that yes, your algebra is off. But if you show what you did, you'll probably get a more precise and accurate answer.
Aug2-08, 11:23 PM   #8
so much for getting an answer on this stuff eh? just a bunch of posts to show how great they are at physics and that you arent
Nov8-10, 03:16 PM   #9
I'm still having problems with this question where do i go from
u1=11m/s
u2=25m/s
s1=s2
t1=(t2+1)
(11m/s)(t2+1)+(4.9m/s2)(t2+1)2=(25m/s)(t2+1)+(4.9m/s2)(t2+1)2
Nov8-10, 05:19 PM   #10
Quote by bfolster16 View Post
u1=11m/s
u2=25m/s
s1=s2
t1=(t2+1)
math is wrong you only insert the (t2+1) onto one side of the equation..
But (t1-1) works better also our g is - because we are throwing the ball against gravity
(11m/s)(t1)+(-4.9m/s2)(t1)2=(25m/s)(t1-1)+(-4.9m/s2)(t1-1)2
This is now corrected^^^
and you just FOIL out
11t+(-4.9t2)=25t-25+(-4.9t2)+9.8t+4.9
cancel (-4.9t2) because its on both sides and simplify for t
New Reply
Thread Tools
Similar Threads for: Kinematics Question (two objects thrown up)
Thread Forum Replies
[SOLVED] Conservation of Momentum and Thrown Objects Introductory Physics Homework 6
kinematics-- ball thrown Introductory Physics Homework 3
1-D kinematics w/ 2 objects Introductory Physics Homework 3
1-D kinematics w/ 2 objects Introductory Physics Homework 0
2 objects 1 up and 1 down thrown Introductory Physics Homework 6
