What is the electric field of a uniformly polarized sphere of radius R?
  • Thread starter Thread starter stunner5000pt
    Sphere
The discussion revolves around determining the electric field of a uniformly polarized sphere with a specified radius R. The problem involves concepts from electrostatics, particularly related to electric fields and potentials in the context of polarization.
  • Participants explore different methods to calculate the electric potential, including direct integration and separation of variables. Questions arise regarding the setup of integrals and the application of boundary conditions. There is also a discussion about the relevance of Legendre polynomials in finding solutions.
Several participants have provided insights into potential methods for solving the problem, including the use of Laplace's equation and the properties of dipoles. There is an ongoing exploration of the implications of polarization on the electric field both inside and outside the sphere, with no explicit consensus reached yet.
Participants note the absence of volume charge density within the sphere and discuss the implications of surface charge density on the electric field. There is also mention of specific mathematical techniques and references to external resources for further understanding.
stunner5000pt
Find the electric field of a uniformly polarized sphere of radius R
[tex]V(\vec{r}) = \frac{1}{4 \pi\epsilon_{0}} \oint_{S} \frac{\sigma_{b}}{r} da' + \int_{V} \frac{\rho_{b}}{r} d\tau'[/tex]
well obviously there is no volume charge density rho
but there is a surface charge density
[itex]\sigma_{b} = P \cos\theta[/itex]
now to calculate the potentail we got to use that above formula
Suppose r > R
then
[tex] V(\vec{r}) = \frac{1}{4 \pi\epsilon_{0}} \int \frac{P \cos\theta}{r'} da'[/tex]
now the squigly r is found using the cosine law right...?
[itex]r' = \sqrt{R^2 + r^2 - 2Rr\cos\theta'}[/itex]
and
[itex]da' = R^2 \sin\theta' d\theta d\phi[/itex]
So then
[tex]V(\vec{r}) = \frac{1}{4 \pi\epsilon_{0}} \int_{0}^{2\pi}\int_{0}^{\pi} \frac{P \cos\theta}{\sqrt{R^2 + r^2 - 2Rr\cos\theta'}} \cos\theta' R^2 \sin\theta' d\theta' d\phi[/tex]
cos theta prime because we care about the Z components only
is that right?
and the limits of integrate for the theta would be from 0 to pi
and for the phi is 0 to 2pi??
thanks for your help
(o by the way how do i put the squigly r??)
Instead of evaluating the integral, you could also find the potential by the separation of variables technique. Since there's no volume charge inside the sphere as you pointed out, laplace's equation will be satisfied.
So, you can find find [tex]V(r,\theta)[/tex] by the separation of variables technique. Since the boundary condition is [tex]V(R,\theta)=P \cos \theta[/tex], the coefficients will be easy to find by the orthogonality property of the legendre polynomials.
A uniformly polarized sphere has a dipole moment p=P*volume.
The outside potential and field are just that of dipole p.
phi inside the sphere can be found by matching the Legendre poynomial expansion for phi at the surface r=R.
Inside a uniformly polarized sphere, the field is uniform.
Outside, the field is like the field of a dipole placed symmetrically about the center with dipole moment equal to the polarization vector times the volume of the sphere.
This can be shown by integration or by separation of variables. The latter method (as stated by siddharth) is neater. You can look at Griffiths for the solution to Laplace Equation in spherical coordinates.
  • · Replies 16 ·
