Castigliano's Theorem on Curved Beams
  • Thread starter Thread starter robip
    Beams Theorem
The discussion revolves around the application of Castigliano's theorem to calculate the deflections of a semi-circular cantilever beam subjected to a radial load. Participants explore both vertical and horizontal deflections, considering the effects of bending moments and axial loads.
  • Homework-related
  • One participant presents an initial attempt at calculating vertical deflection, yielding a formula that is later questioned for accuracy.
  • Another participant provides a detailed derivation for vertical displacement using Castigliano's theorem, arriving at a different expression.
  • Questions arise regarding the interpretation of the radial load and its direction, with some participants suggesting the need for a diagram for clarity.
  • There are discussions on the axial load's contribution to deflection, with suggestions to decompose stresses into components.
  • Multiple participants express uncertainty about their calculations and seek verification of their results.
  • One participant notes a discrepancy in the moment of inertia calculation, comparing their result with a textbook answer.
  • Another participant suggests that axial loads may not need to be explicitly included in the calculations, prompting further exploration of the topic.
There is no clear consensus on the correct approach or final expressions for deflections, as participants present differing methods and results. Some participants agree on certain calculations while others challenge them, indicating ongoing debate and uncertainty.
Participants mention various assumptions and dependencies in their calculations, such as the geometry of the beam and the definitions of variables. Some calculations appear to rely on specific interpretations of the loading conditions and beam properties.
This discussion may be useful for students and professionals interested in structural engineering, particularly those studying beam deflection theories and applications of Castigliano's theorem in curved beams.
robip
You have a semi-circular cantilever with a point radial load at its free end.
i.e load acting down from top of semi circle, with bottom attached to something.
Calculate the equations for the horizontal and vertical deflections taking into account both bending moments and axial loads using castiglianos theorem
Ok I gave it a go and compared it to some experimental data and found I was a bit off.
I got dV=LR^3/2EI
with L = load
R = Radius
E = Youngs Modulus
I = moment of inertia bh^3/12
You could show your attempt so we can determine where you went wrong.
Well here is how I got it:
M(theta)=L*R*Sin(theta)
dM/dL=RSin(theta)
dV=dU/dL=d(int(M^2/(2*E*I)*r*dTheta,Pi->0)/dP
=1/EI * int(M*dm*R*dTheta,Pi->0)
Substituing values for M(theta) and dM
PR^3/EI * int(sin^2(theta)dTheta,Pi->0)
dV=PR^3/2EI
Hey robip, a few questions when you mean the load is radially wouldn't the load be horizontal (because of the geometry properties of a semi circle)?
Also would you care to post a diagram with the geometry of the problem?, I'm not seeing what are the variables on your work, besides the obvious L.
Vertical Displacement case:
So for a thin curved-beam, taking as our ind. variable theta and L will be the force by Castigliano, then we have:
[tex]M(\theta) = (-R \sin \theta)(L)[/tex]
[tex]\frac{\partial M}{\partial L} = (-R \sin \theta)[/tex]
Ok, then L = P,
[tex]M(\theta) = (-R \sin \theta)(P)[/tex]
and
[tex]\Delta = \int^{\theta}_{0} M (\frac{\partial M}{\partial L}) \frac{R d \theta}{EI}[/tex]
[tex]\Delta = \int^{\pi}_{0} ((-R \sin \theta)(P)) (-R \sin \theta}) \frac{R d \theta}{EI}[/tex]
[tex]\Delta_{free-end} = \frac{P \pi R^{3}}{2EI}[/tex]
Anyway, it looks like your work is accurate. This is what i got.
robip said:
dV=PR^3/2EI
You forgot the pi in your answer.
i can't believe i didn't notice all my values were out by about 3... :smile:
so for the horizontal i would just use Cos instead right?
More like [itex]R - R \cos \theta[/itex].
oh yea, i see, thanks so much for the help!
really appreciated
really appreciated
No problem :biggrin: , and welcome to PF!.
hmmm i just realized it is also asking for the axial load to be included in the equation, how would i calculate the axial load at any point with respect to angle theta?
Use your geometry knowledge to decompose the axial component of the stresses in x and y, and then do sums of forces in y and x.
Remember the axial component is tangential to the circle, and the radius is perpendicular to tangents.
hi robip,
I would be interested in seeing the rest of your workings and results for this particular problem as i am doing something similar atm.
Much appreciated
Cheers
Hi robip,
Are you a student at curtin university of technology in Perth, Australia, by any chance? :)
.Ksum006
OK, so for horizontal this is what i got:
(3*pi*P*R^3)/(2EI)
I did this using the same process as the vertical, but using M(theta)=(R-Rcos@)*P.
Is the above answer correct? I am not very good at calulus and this is where i may have come stuck:
dh=(PR/EI)*[Integration between Pi and 0 of (R-Rcos@)^2.d@]
I have a similar question but with a 3/4 cantilever. The answers are on the attachment but can't get them using the formula supplied - Any ideas?
i seem to be doing the same question and i am able to do the first part of the vertical displacement, as stated above, but i can't get an equation for the axial load in terms of the applied load P. and having it as a function of theta.
anybody can help me how to derive an equation of deflection of circular bar by using castigliano theorem ?...the final answer is like this:
δ_v=∂U/(∂P_v )=(P_v R^3)/EI (π/4-2/π) )
I see there are many questions related to Castigliano's theorem with thin curved beams. I recommend reading this website http://school.mech.uwa.edu.au/~dwright/DANotes/MST/thin/thin.html#thin".
I have the exact same problem as robip. "Calculate the equations for the horizontal and vertical deflections taking into account both bending moments and axial loads using castiglianos theorem".
I have read the website http://school.mech.uwa.edu.au/~dwrig...thin.html#thin. but I am still not 100% certain of my answer.
My attempt at the solution.
For vertical deflection due to axial load:
Paxial = Psin(theta)
dP(axial)/dP = sin(theta)
vertical deflection= (1/EA) * int( Paxial * dP(axial)/dP * R )d(theta) with limits 0->Pi
= (1/EA) * int( Psin(theta)*sin(theta)*R )d(theta) with limits 0->Pi
=(PR/EA) * int( (sin(theta))^2 )d(theta) with limits 0->Pi
=(PR/EA) * (Pi/2)
=(P*PI*R/2EA)
For horizontal deflection due to axial load:
Paxial = Pcos(theta)
dP(axial)/dP = cos(theta)
horizontal deflection= (1/EA) * int( Paxial * dP(axial)/dP * R )d(theta) with limits 0->Pi
= (1/EA) * int( Pcos(theta)*cos(theta)*R )d(theta) with limits 0->Pi
=(PR/EA) * int( (cos(theta))^2 )d(theta) with limits 0->Pi
=(PR/EA) * (Pi/2)
=(P*PI*R/2EA)
I.e. Horizontal deflection and vertical deflection due to axial loading is exactly the same.
Verification of my solution would be very much appreciated.
I am a little rusty as when I solved this problem I had just graduated with BS in Structural Engineering. However, I went to graduate school in economics (funny, eh?).
I remember Castigliano Theorem(s) fairly well, and from my solution of vertical displacement, I can tell your vertical displacement is wrong. Your lever arm is wrong! you forgot another R!, also your partial derivative inside the integral is wrong.
For the second part,
I believe you don't need to take into "account" the axial load. Take the reference point with respect to the edge of the section, and the apply Castigliano again by putting an horizontal fictious load. The lever arm should be the one I gave in a previous post [itex]R-R \cos \theta[/itex]. The reason is that when you cut a section, you aggregate the stresses into equivalent Force-Couple systems. In this case, you decompose the force into a radial (shear force), and a tangential (axial force), and you also have the couple (or moment). If you take moment with respect to the section, then the lines of action of both shear and axial gives radius vectors of length 0, and thus moments of 0 with respect to it. However, the couple still counts.
Good luck!
I was able to get it in the end. Thankyou for your help!
If i wanted to calculate I in this problem would it simply be as follows:
I = (pi*P*R^(3)) / (2E) ?
and thus substituting values in if we take
E = 69 GPa
R = 150 mm
P = 0.1 N
we get I = 1.28 *10^(-14)m^(4)
The answer i get in my textbook however reads - 1.63*10^(-28)m^4
Am i doing something wrong?
Thank you for your time.
vertical deflection = (pi*P*R^3) / (2EI)
Therefore,
I=(pi*P*R^3) / (2E*vertical deflection)
Hope that helps
Can you solve for I any other way - other than using that equation without vertical deflection and or horizontal deflection?
I think you can use
I=bh^3/12 where b and h are the width and thickness of the beam respectively.
Hi thanks for the reply,
is that (bh)^3/12 or b (h^3/12)
b (h^3/12)
How to find deflection in a circular ring subjected to tensile forces along the diameter?
Means, take a circular ring and pull it on the opposite sides...
  • · Replies 17 ·
  • · Replies 16 ·
